Lusso love/hate
We've been together for 8 years but the last week has been tuff. The lusso has been on the shelf for the past 6 months due to lack of ambition and not wanting to hear the sob story of how hard the parts are to get for whatever kind of machine that thing is. So I took a crack and stripped it down- new wiring and gaskets. All was looking good until I realized the water connection to the group head has broken loose. Question: what do I do? And has anyone else had a similar experience.
- drgary
There are several machines called Lusso. Which is yours? I am thinking it may be Ponte Vecchio because I've heard of fittings soldered to the boiler that have since been upgraded. Can you show us photos please?
LMWDP#308
LMWDP#308
Yes it is the PV Lusso I believe in I have tracked down the parts now it's a matter of getting them on. Does anyone know if I can unsolder the flange?
- Sponsor
Pics would help, but yes you should likely be able to un-solder provided you can throw enough heat at the joint. Smaller parts are easier to do with regular propane torch.
I think I have the same grouphead, as last resort you can drill and tap a 1/4 npt into it no problem and connect whatever you want. You may be able to do 1/8 npt depending on what you have, but mine was 1/8 bsp and so I had to go larger. I used a barb for ptfe tubing, but you can use whatever you like.
Get a tap like this http://www.amazon.com/Vermont-American- ... ap+and+die and drill with a 7/16 bit (or 3/16 for 1/8) about 5/8 inch into the grouphead should be enough. Make sure you clear out any debris so it doesn't plug the hole going into the grouphead.
I have tried heating it but nothing is breaking loose. It seems to be welded. Has anyone been down this path?
