Better knob for LIDO 2
- FotonDrv
I have had this Lido 2 for a long time and like it very much for the purpose I purchased it. I initially had a problem with being able to grasp the knob that was OEM so I changed it to a fishing reel knob that I found online. It worked fairly well but I hated the darn gold look of it (they sent the wrong reel knob, should have been black). I tried to locate a Pharos knob without success although I did not put much time into the search.
When the Mahlgut grinder came out I noticed it had a similar knob as the Pharos (maybe the same knob) and so when I inquired of them if I could buy a knob from them they said I could, or I could buy it directly from the manufacturer and they provided the link.
Here is the result which works perfectly and is much stronger than the fishing reel knob. It has a 10mm shaft threading.
https://www.ganter-griff.de/en/products ... es-Plastic
- Boldjava
Danhke, I have large hands as well and this will help me.
Requested a quote from them.
DB
DB
LMWDP #339
LMWDP #339
- FotonDrv (original poster)
1.85 from top of rubber to bottom of rubber.
All I did to mount it was drill and tap the crank for the 10mm threads.
- weebit_nutty
nice looking knob.
Orphan Espresso's upgraded knob is a huge improvement over the original one. But I would have prefered the round shape, too.
Nice knob. The stock LIDO knobs leave a lot to be desired in my opinion.
But with tax and "processing fee" it's about $24. Wouldn't you just be able to buy a knob at the hardware store for a couple of bucks?
The first thing I did when I got my Lido2 was to replace the original flat handle with a golf ball. I drilled the ball with a bit, added a little oil for lube and placed it on the post. It makes it much easier grind hard beans because I have the earlier itallian burrs. Oh yeah, the mod was basically free because I have about billion golf balls. If you want to get specific, it is Hogan Tour 4 piece ball (those were great balls).
Not like that one. "Soft" knob with bearings, a hex key shaft to hold the shaft and screw it into the crank and the ability to hold it while locking down the lock-nut. All in all s good deal.jpender wrote:Nice knob. The stock LIDO knobs leave a lot to be desired in my opinion.
