What would be your ideal lever espresso machine? - Page 6
- cuppajoe
Guess it depends on your idea of 'near repeatability'. I roast a wide variety of SO's to a range of roasts, and blend post roast for morning capps. Other than the Faemina, the machines I use vary greatly, both lever and pump. I have one electric grinder and three manuals, also subject to rotation.mathof wrote:While absolute repeatability is an unreachable ideal due to the innumerable variables that influence each shot, near repeatability is necessary to dial in a coffee. Without that you would be completely at sea when determining the best combination of brew temperature, fineness of grind, quantity of dose and liquid in the cup to bring out a flavour from the coffee that you like.
Matt
If near repeatability means that without much fuss I can dose, grind, and brew a decent cup of espresso, then it is achieved. If it means cranking the same-ish tasting stuff out shot after shot, then no. For me, a large part of the enjoyment is being pleasantly surprised with each cup.
David - LMWDP 448
- drgary
My Prestina with PID hits the mark for repeatability and temp control in a home environment. I used it in the last favorite espressos review.
LMWDP#308
LMWDP#308
- pizzaman383
- Supporter ❤
Achieving shot to shot consistency was one of the primary design goals with my FIT dipper lever. The combination of temperature control in temp monitors gives excellent consistent results.
Curtis
LMWDP #551
LMWDP #551
