Profitec Pro 700 chirping sounds from the group during brew [SOLVED]
F1
#1: Post by F1 »
I remember somebody mentioning this problem in another Profitec 700 thread. No reason or solution was mentioned at the time. Anyway, I have the same sound coming from the group when the basket reaches full pressure(9bar). In the other thread it was described as a dolphin call sound and that is exactly how it sounds like. The sound lasts between 1 and 2 seconds and happens 8 out of 10 times now. It happens with coffee in the basket and with the backflush disk. I have had this issue since the machine was new a few months ago, but it has gotten more frequent as time has passed.
Did any of the Profitec 700 owners find a cause/solution to this?
spearfish25
#2: Post by spearfish25 »
A video might be helpful but I think you're describing the sound as one of the seals engages as the system pressurizes. It's always worse after a chemical backflush and then after 20-30 shots it mostly goes away. It's just a lube issue and coffee oils are usually enough to make it go away.
______________
Alex
Home-Barista.com makes me want to buy expensive stuff.
F1 (original poster)
#3: Post by F1 (original poster) »
It had this sound from the moment I got it. I guess Profitec went cheap on the lube at the factory. I'll put some lube on the valves over the weekend and report back.
#4: Post by F1 (original poster) »
It turned out to be lube or lack thereof. I unscrewed the mushroom and put a tiny bit of lube on the brew valve tip only. It's been a week and about 20 shots later no chirping sound.
Don Task
#5: Post by Don Task replying to F1 »
Thanks for the followup! Greatly appreciated! :D
There's nothing more aggravating than a thread discussing a problem that goes dead (assuming this occurs after the OP fixed the problem) but then never checks back in with what the solution was or if it the problem was ever resolved.
Krups, then Silvia, then Livia 90, then a Techno! Does it ever end? [sigh]
spearfish25
#6: Post by spearfish25 »
Agree fully. I guess some problems just don't get solved though.
______________
Alex
