Baratza Vario Grind Settings - Page 2
I always found that the sound of the running motor's load made for finer adjustment than trying to use the numbers/letters. So if I went from 2A to 1-anything I'd listen to the motor on 2A, then pull the fineness slider down to about Q. The motor load will lessen. Then bump the macro up to 1 and the load will increase. Now adjust the fineness slider to match the original 2A load sound. Now you're in the 1 macro range in a similar spot to where you were in the 2 macro range. Now adjust fineness to your new desired setting.
______________
Alex
Home-Barista.com makes me want to buy expensive stuff.
Alex
- NightFlight
My apologies Ruben, after going back through my manual I realized that my knowledge regarding this behavior is a result of experience and this website.rubenhak wrote:Can you reference the exact sentence from the manual that describes this behavior? Here is the link to the manual in case you would need it:
No worries. But it is a shame that the manual is so poorly documented.
