Victoria Arduino Adonis temperature calibration and service
ZSJAF
Postby ZSJAF » Jan 10, 2019, 2:07 pm
New guy here and first post. I have just purchased a lightly used Victoria Arduino Adonis for a coffee bar that I will be building in the future. I am going over it with a fine tooth comb. I hope to hear from guys/technicians familiar with this machine or other Simonelli's.
1. What is the best way to check temp? Temp prob in water stream, check water in cup, temp gun?
2. I hope to hear from someone familiar with this machine. I have thoroughly cleaned it and components multiple times. Zero leaks or error messages. I have changed the group head components gaskets, ect. What other items should be checked, serviced or overhauled?
Thanks in advance.
shawndo
Postby shawndo » Jan 10, 2019, 2:28 pm
Fairly standard way to check the temperature:
https://www.espressoparts.com/search/?q=scace
There is also an option that also measures the pressure.
Darmok and Jalad at Tanagra
ZSJAF
Postby ZSJAF » Jan 10, 2019, 3:08 pm
Those tools would definitely do the job. Is there another way to check it more economically?
shawndo
Postby shawndo » Jan 10, 2019, 4:12 pm
More economical is the classic styrofoam cup test. I normally dont think economical when I think Victoria Arduino :P
Poor Man's Brew Temperature Measurement
You can search for "espresso machine styrofoam cup" for more info/variations
ZSJAF
Postby ZSJAF » Jan 11, 2019, 4:22 pm
Thank you sir. That is what I will try to start with.
