Vesuvius Steaming Performance?
- wingnutsglory
- Supporter ❤
I'm looking to upgrade from a Duetto 2 and the Vesuvius is in the top 3. My concern is with it's steaming performance, specifically as it relates to the Duetto. My guess is that the Vesuvius will be pretty close, but I'd like to put the question out there and see if others have any input based on experience. I'm typically doing only about 25% cappuccinos with the rest being espresso and Americanos, but I do value good steaming ability.
I can't compare it to your current machine , It has a decent boiler and will steam milk , unless you require commercial performance then i can't see why you would have a problem with a vesuvius.
I have not used either machine, but they are both dual boiler machines and should have excellent steaming power. The specs are a little different, but I would not expect to notice much of a difference if any.
Vesuvius
1.5 liter steam boiler, 1400 watts
Izzo Alex Duetto II
1.8 liter steam boiler, 1200 watts
Rocky
Vesuvius
Izzo Alex Duetto II
Rocky
If your Duetto II has no pressurestat, then steaming performance will be much better with the Vesuvius. If it does have a pressurestat, the steaming will be a little bit better.wingnutsglory wrote:I'm looking to upgrade from a Duetto 2 and the Vesuvius is in the top 3. My concern is with it's steaming performance, specifically as it relates to the Duetto. My guess is that the Vesuvius will be pretty close, but I'd like to put the question out there and see if others have any input based on experience. I'm typically doing only about 25% cappuccinos with the rest being espresso and Americanos, but I do value good steaming ability.
- wingnutsglory (original poster)
- Supporter ❤
I believe it's temperature regulated so no pressurestat. I guess I never have been super clear on how much of a difference that makes and haven't tried a machine that uses one recently, at least not a machine with a non-commercial size steam boiler less than 2L.
I wonder if it makes much difference that the Vesuvius is (seemingly) limited to a 15A mode in the US, where the Duetto can handle 20A and heat both boilers simultaneously. That does seem to help steaming with the Duetto (20A vs 15A).
I previously had a Profitec Pro 700 that could selectively handle 15 or 20 amps. I switched to a Vesuvius V2 about 5 months ago.
I believe that the programming of the Vesuvius seems to constantly switch power every few seconds from steam boiler to brew boiler and overall it does a better job of maintaining steam temp/pressure at 15 amps than the Profitec did at 20 amps enabling simultaneous boiler heating. Overall, I'm quite pleased with the Vesuvius steaming capabilities. I definitely would not go back to non-pressure profiling espresso machines.
Edit:If your Duetto II has no pressurestat, then steaming performance will be much better with the Vesuvius. If it does have a pressurestat, the steaming will be a little bit better.
I wonder why dual boiler machines in this class would have a PID instead of a pstat in the first place. When steaming, who would be interested in keeping the steam boiler at a steady temperature; just to have enough heating power to produce abundant steam to me seems more important than trying to modulate the heating output depending on the fall in temperature.
Bert
- aecletec
With PID steam you can adjust the temp and therefore pressure easily...
- Supporter ❤
My understanding here is that you take a hit on responsiveness of the system (and steaming perf.) with a measure of temperature lagging that of pressure...? I guess it depends somewhat on the probe itself and its position in the boiler.
