Synesso for Home - Page 21
- baldheadracing
It's just a material, with pluses and minuses. It's how the material is used that matters.exidrion wrote:I thought brass was considered a really bad idea these days...
In addition, brass is much more expensive (in both material and processing) than it used to be.
- JohnB.
In this case the brass is being used to make a group which will hold the water you'll be drinking. With all the strict regulations concerning lead leaching & brass it seems an odd choice particularly since they are heating the group. Stainless seems to be the material of choice these days. Kees redesigned the Speedster in 2020 to eliminate all remaining brass in contact with the water.
LMWDP 267
The question is whether the switch to stainless was because of cost, or is stainless really the preferred material?
- JohnB.
Kees went with a stainless group & boilers in 2008 & I seriously doubt it was to save a few bucks. The recent redesign was to eliminate any water contact with brass.
LMWDP 267
Modern brass is lead free. What I also found on the marlin wire.com:
Brass is a better heat conductor.As noted in the FDA's Food Rule, "copper and copper alloys such as brass may not be used in contact with a FOOD that has a pH below 6 such as vinegar, fruit JUICE, or wine or for a fitting or tubing installed between a backflow prevention device and a carbonator."
- baldheadracing
Perhaps they are drawing from their existing designs and parts? The thermal characteristics of brass are quite different from stainless steel. Designing a completely new group may not make economic sense at the volumes of ES-1's that Synesso is expecting to make.JohnB. wrote:In this case the brass is being used to make a group which will hold the water you'll be drinking. With all the strict regulations concerning lead leaching & brass it seems an odd choice particularly since they are heating the group. Stainless seems to be the material of choice these days. Kees redesigned the Speedster in 2020 to eliminate all remaining brass in contact with the water.
Regardless, stainless steel - to be specific, 304 - is popular these days for some applications like boilers primarily because it is now less expensive than brass once machining costs, regulatory requirements, and (EU) reporting burden are included. (Some high-end machines use 316; a different situation.)
A Speedster is in a different price bracket - assuming that the ES-1 is priced competitively with the GS/3. If the ES-1 is eventually sold at Speedster prices, then that would be a different matter.
Just to update you lads on the ES1... got some definite news that it will be first released in the states then worldwide distribution should start in December.
The thing I didn't like is that it seems they upped the starting price from "GS3" range (which costs around 7700 USD locally) to 9k-10k USD.
Well it seems I am gonna stick a bit more with the bianca.
Unless you roast your own coffee, You still didn't reach 90% of the rabbit hole.
Seems like it moves further back every time it get somewhat close
I'm just glad I'm not remotely tempted by it - the lack of real time paddle control is a fatal flaw imho
