Slayer single group - vibrates on 0 bar
Amal S
#1: Post by Amal S »
Hey
I have Slayer single group and it does vibrate on 0 bar without portafilter but if I used blind basket there's nothing.
anyone had this problem before?
Check video
spressomon
#2: Post by spressomon »
Have you contacted Slayer? The few times I have needed their help on a tech issue they have been great.
No Espresso = Depresso
Amal S (original poster)
#3: Post by Amal S (original poster) »
I did but Unfortunately they are not great.
UrKurt
#4: Post by UrKurt »
With water flowing through the group but nothing allowing pressure to build, the gauge will read 0. If it continues to read 0 even when pressurized, either there's something wrong with the gauge itself, or there is a blockage somewhere between it and the connection to the brew group (either in that narrow copper tube, or its connections). My money is on blockage.
ira
#5: Post by ira »
I'm going to guess cavitation. The inlet is restricted and the pump can't get enough water and the bubbles are causing the vibration.
#6: Post by Amal S (original poster) »
I will check.
#7: Post by Amal S (original poster) »
ira wrote:I'm going to guess cavitation. The inlet is restricted and the pump can't get enough water and the bubbles are causing the vibration.
You mean the inlet hose can't get enough water for the pump?
ira
#8: Post by ira »
Yes, maybe the filter is clogged or the hose is crimped.
