Slayer espresso machine at 220V - Page 2
- CarefreeBuzzBuzz
Put a ribbon around the wire in your favorite color and call it a decoration and a day!
You can easily convert that 220 outlet to 120 (at your breaker box) and use it for whatever - grinder, another machine, etc
- HB
- Admin
The main difference is recovery time, and that only matters if you're rapidly making 6+ back-to-back "big gulp" type lattes. Most commercial espresso machines that run on 120V compensate by having a bigger steam boiler. The 220V ones have both a huge steam boiler and zero recovery time. For example, the 2 group Strada can steam paint bucket-sized lattes from both sides and the steam pressure will not drop. That might matter if you run a busy cafe with really fast baristas, but not in a home environment.peafarmer wrote:He also said that the 120 volt machine was for practical purposes just as good, just like some of you said. That made me think: why do they even make the 220 volt machine, then?
- Mayhem
Because the US is not the only country in the world, and many including all of Europe have 220 VAC in our outlets...peafarmer wrote: He also said that the 120 volt machine was for practical purposes just as good, just like some of you said. That made me think: why do they even make the 220 volt machine, then?
Too much is not enough
Thanks, guys. I have both a 220 V and a 120 V receptacle at that location. Also, these cables are already run behind the drywall, so I would need to cut the drywall to put a ribbon on the cable as CarefreeBuzzBuzz suggested.
I will use that power (ir)regardless of whether it makes any sense. I have that right.
I've widened my search, now looking at new Londinium I / R24, Rocket R NINE ONE, both on European voltage. These are significantly cheaper than a new 220V Slayer, and seem very capable.
Many of my family members like milk drinks. I imagine that the Rocket is very good with steam. Does anybody know how good the steam is on the Londinium machines? My son is spoiled. He uses a La Marzocco Classic two group machine at the bakery where he works part time, so I am hoping to get close to that steam quality. We had a VBM Domobar which just died, and I was never able to steam well enough with that to do art. I know this is not the right forum for this question, will also post under lever machines tomorrow.
Thanks,
Andy
Thanks,
Andy
