I have a light roast that I've been pre-infusing for 15 seconds, then ramping to 9 bar for an extended extraction. It surprisingly tastes great, but I'm wary of repeating the recipe due to the extended duration of stress on the pump. I have an ECM Classika which has a vibe pump and I've read that it's not great to run it longer than 60 seconds. So that's basically my question - Is running my vibe pump longer than 60 seconds problematic?
Correspondingly, if it is, then what about backflushing? I backflush in 10 second intervals; 10 on, 10 off, 10 on (etc...). I do this 5 times with cleaning powder, then 5 consecutive times without the powder. So, if the above 75 second pull is an issue, is my backflushing also problematic?
Thanks!
Running vibe pump around 75 seconds
These pumps are designed for relatively short-duration use, spec-ed at 20°C water in a 25°C environment, which aren't typically met in home espresso machines.
From /downloads/ ... models.pdf
EAX5 -- 1 min on, 1.5 min off
EX5 -- 1 min on, 1 min off
EFX5 -- 2 min on, 1 min off
The good news is that when they fail (which they do even with "normal" shots with a typical E61 box), the EX5 is around $30 and, when you can find them, the EFX5 around US$50.
The better-designed machines will have a "Klixon" over-temperature switch on the housing of the coil, which should help prevent catastrophic overheating.
