Rocket R58 v2 lever function
holmbow
#1: Post by holmbow »
Hi all,
Just bought a used Rocket R58 v2 and been using for a few weeks now.
Something that wonders me is why the pump audibly activates at the middle position, the pressure gauge ramps up to 9 bars, but no water flows through. Then when I lift it slighty more the water is let through with full flow, not just "pre-infusion". Shouldn't it be silent at the middle stage with a light drizzle, lifting it slightly more the "pre-infusion" should start and then full on should be with active pump and full flow?
Can't really seem to get the "pre-infusion" state to work.
StoicDude
#2: Post by StoicDude »
Just to clarify and not assume, is it plumbed in or tank operated?
Jake_G
#3: Post by Jake_G »
holmbow wrote:Something that wonders me is why the pump audibly activates at the middle position, the pressure gauge ramps up to 9 bars, but no water flows through.
The pump actuates when the cam on the lever depresses the switch behind it.
You can adjust how far out the switch protrudes and eliminate this if you want to.
Cheers!
- Jake
LMWDP #704
holmbow (original poster)
#4: Post by holmbow (original poster) replying to Jake_G »
#2 Tank operated:)
Is it as easy as turning the switch from the outside, or do I have to open up the machine?
Jake_G
#5: Post by Jake_G »
holmbow wrote:#2 Tank operated:)
The E61 I had was sandwiched between to slim nuts, so had to open the case to reach the inside one. Not sure on the Rocket.
LMWDP #704
#6: Post by holmbow (original poster) replying to Jake_G »
Thanks a lot. Seems to be the case here too. Thanks.
StoicDude
#7: Post by StoicDude »
This is how mine looks when the lever is at 45. I was going to say the same thing and point to the switch.
#8: Post by holmbow (original poster) »
Just found that mine is such a microswitch, which only use a single slim nut. How would I approach this?
#9: Post by holmbow (original poster) »
I just went for it, took off the sides of the machine and inserted an appropriate washer. Working lige a charm now :)
