Rancilio Silvia Pro - Dual boiler PID espresso machine
Silvia Pro is the 1-group espresso machine that provides precision and control over every shot, with limited footprint thanks to its compact design.
Silvia Pro is a blend of the professional performance of Rancilio espresso machines and the remarkable capabilities of Silvia - with the addition of two PID, a digital display, two independent boilers and a wider range of coffee solutions, designed to provide the best coffee experience and to meet the needs of expert baristas.
Silvia PRO is equipped with two separate boilers, both equipped with PID: one boiler is dedicated to heating the water for coffee, and the other is a steam boiler for hot water and steam.
more info here: https://www.ranciliogroup.com/app/uploa ... pdf#page=9
and here https://www.ranciliogroup.com/rancilio/ ... ilvia-pro/
LMWDP #630
- Jake_G
Well, well, well...
This should be very interesting.
Thanks for sharing!
- Jake
Thanks for sharing!
- Jake
LMWDP #704
- slybarman
Any word of price?maki wrote:image
- C-Antonio
The specs indicated they used the same size brew boiler and an 1 liter for steam... plus the PIDs lots of stuff crammed in a small machine...
“Eh sì sì sì…sembra facile (fare un buon caffè)!”
- baldheadracing
Pro is a bit wider, but taller and quite a bit deeper.
Silvia: W × D × H
235 x 290 x 340 mm
9.2 x 11.4 x 13.4 in
Pro: W × D × H
250 x 420 x 390 mm
9.8 x 16.5 x 15.3 in
My version of a Silvia double-boiler is a Micro Casa a Leva parked beside my Silvia .
Silvia: W × D × H
235 x 290 x 340 mm
Pro: W × D × H
250 x 420 x 390 mm
I hope this works out, and for an affordable price. Though I'll take a wild guess at $1500. The only thing more I could ask for is a plumbed in option for under the cabinet use and my sheer laziness.
LMWDP #730
No kidding! This is really very exciting!! Hopefully it will be priced for less than the Profitec Pro 300 ....Jake_G wrote:This should be very interesting.
Now, if only Rancilio will also release a home spring-assisted lever machine (other than their commercial Classe 5/6) .....
LMWDP #115
- Randy G.
I wonder where they got the idea to put a PID on a Silvia?
A bit of history in my Chapter 63 - Me Be PID from 2003. Others came well before my installation, but the new "Silvia Pro" has been a long time coming.
The original Silvia was about 1400cu.In. The Pro about 2500cu.in.
This machine should have been released like 5 years ago, nowadays its just not relevant any more ...
If it's the same quality as the Silvia it will be mostly a known product. Compact, very reliable and easy to keep clean with just a wipe of a cloth. The Rancilio may be outdated but it's hard to argue with the build quality and as the two biggest complaints, lack of temperature stability and steaming are addressed it should be a fairly easy to use and trouble free machine.
LMWDP #730
