Quickmill Anita - help me diagnose problems and repair - Page 2
Also, you should consider changing the O-ring on the bottom part of the OPV, as well as using teflon tape when reinstalling it.
Henry, you are right, my vacuum breaker valve looks exactly like one on your picture.
As for OPV "piston" insert - I need to locate it first.
Is it the same valve that is used to adjust a brew pressure?
I am just getting familiar with my machine's internals. Is there a good picture with the parts named or explosion diagram for Anita?
Yes, that's the valve. Have a look at http://coffeetime.wikidot.com/local--fi ... _Valve.pdf for a detailed article on how it works. On page three of the pdf, you'll see a good image of the valve taken apart. Yours is the rightmost one depicted.
As far as good images of the insides of your machine, I find that erics seems to have a fantastic collection of them. I keep a folder of them for reference.
I have disassembled vacuum breaker valve today. That little rubber ring was completely dry and fell apart when I tried to remove it. That explains why a steam was escaping. I cut off a new rubber ring but did not succeed in it - a steam is escaping even more. I will be ordering new vacuum breaker valve from Chris.
I was able to remove only the first 3 parts of the valve, the base and the "cup washer" remain attached to the boiler. Should I just apply more pressure or are there more civilized ways to remove it?
After that I have separated the flow from OPV and priming valve attached to the pump as Eric suggested in this topic:
Line A goes to the pump suction - this can remain untouched.
Line B comes from the OPV.
Line C comes from the priming valve attached to the Ulka pump.
I did 15 second flush and measured the water from both lines. Line B output was 2 oz, line C was 0.75 oz. Thus looks like something is wrong with OPV. I will disassemble it to take a look.
I have disassembled OPV, the rubber seat has multiple cracks on top of it and the rubber part is very brittle. I will order it too. Does Chris sell the insulation for the boiler? In my machine it is all cracked and falling apart.
- erics
- Supporter ★
No.Should I just apply more pressure or are there more civilized ways to remove it?
The lower portion of the vacuum breaker valve, along with all of the other water/steam fittings on the boiler, is sealed with thread sealer. I removed mine with a small, ADJUSTABLE, air impact wrench but this is a job not suited for the average home-barista - you can end up twisting some lines you didn't intend to. Espresso machine fittings are "sorta" a combination of english and metric sizes and a good fit with either is the exception rather than the rule.
You MAY be able to order all of these parts from Great Infusions - http://www.greatinfusions.com/ - they buy a lot of machines from Chris' Coffee. Your list should include: new vacuum breaker, silicone hose, OPV insert, OPV adjuster o-ring (as per Mike's suggestion), small tube of food-safe lubricant, new style boiler insulation (about $15-20 BTW). I would order two of the OPV inserts and a spare shower screen/grouphead gasket while I was at it.
- erics
- Supporter ★
In addition, and borrowing Henry's pic, I refer to the numbered parts below:
A new teflon valve seat (2) CAN BE a tight fit in the housing (5). I would heat the machine up for about 15 minutes (use the on/off switch to avoid steaming up your work space) and then insert the new valve (3) and valve seat (2). Teflon tape/thread sealer is not necessary here - the new top (1) compresses the seat (2) and seals it well.
Spare o-rings for the vacuum breaker and others are as listed here: O-rings & Copper Sealing Washers.
Eric, thank you for the advice. I start to understand more but still have a lot of questions. I do not see all those parts listed on Great Infusions web site. Should I just give them a call and order over a phone?erics wrote: You MAY be able to order all of these parts from Great Infusions - http://www.greatinfusions.com/ - they buy a lot of machines from Chris' Coffee. Your list should include: new vacuum breaker, silicone hose, OPV insert, OPV adjuster o-ring (as per Mike's suggestion), small tube of food-safe lubricant, new style boiler insulation (about $15-20 BTW). I would order two of the OPV inserts and a spare shower screen/grouphead gasket while I was at it.
As for "new vacuum breaker" - do you mean that I do not need to remove the housing and should just replace the internal parts (2,3 and 4) inside the valve?
"OPV adjuster o-ring" - is it a rubber ring around a bottom part of OPV?
- erics
- Supporter ★
Yes, and whatever parts they don't have, e.g. boiler insulation, Chris' Coffee does.Should I just give them a call and order over a phone?
As regards the vacuum breaker, leave the housing in the boiler and replace parts 1,2,3,& 4.
The o-ring for the OPV adjuster is not necessarily mandatory but would, most definitely, be a very good idea. You will only see the o-ring when you fully unscrew the adjustment - have several paper towels below to catch the drips.
One last question: Great Infusions sells 2 sizes of vacuum breaker valves : 3/8" fitting and 1/2" fitting. Which one do I need?
