Post a pic of your home espresso setup... - Page 653
BaristaBoy E61
#6521: Post by BaristaBoy E61 »
Peter_SVK wrote:Yes, that's "single dosing" small hopper. When I bought the grinder, there was not available original MK small hopper, so managed to made this one. I use it with the weight
Thanks for the reply. Yes, it's as intriguing as it is beautiful.
Would you happen to know if it would work on the Mahlkonig K30 Vario?
Peter_SVK
#6522: Post by Peter_SVK »
No, it won't, it's designed specifically for original E65S hopper base and K30 and E65S hoppers are not interchangeable. Moreover, only 1 pcs. exists in the world. :lol:
indend007
#6523: Post by indend007 »
Finally I modified my speedster Idro-matic version. Original PPIC function is removed, so now I use Idro matic tune only. Looks more aggressive and extraction make interesting result.
Peter_SVK
#6524: Post by Peter_SVK »
That's a serious machine! Congratulations.
JohnB.
#6525: Post by JohnB. »
indend007 wrote:Finally I modified my speedster Idro-matic version. Original PPIC function is removed, so now I use Idro matic tune only. Looks more aggressive and extraction make interesting result.
Are you still using the needle valve & larger jet? If so how does that work with the Idro-Matic? I tried it with both the PPIC/I-M working together & just the I-M. Ended up disconnecting the PPIC as you have & just running the Idro-Matic.
LMWDP 267
BaristaBoy E61
#6526: Post by BaristaBoy E61 »
indend007 wrote:image
They don't come more beautiful than that - Congrats!
What have you noticed regarding taste and grind adjustment?
indend007
#6527: Post by indend007 »
JohnB. wrote:Are you still using the needle valve & larger jet? If so how does that work with the Idro-Matic? I tried it with both the PPIC/I-M working together & just the I-M. Ended up disconnecting the PPIC as you have & just running the Idro-Matic.
I'm using I-D only, needle valve kit is also removed. :P I'm considering modify PPIC, i.e) add adjustable kit like this. If this works well, PPIC cylinder volume can be adjustable or on-off.
indend007
#6528: Post by indend007 »
BaristaBoy E61 wrote:They don't come more beautiful than that - Congrats!
Sooner day, I'll post some videos about it. :P
JohnB.
#6529: Post by JohnB. »
indend007 wrote:I'm using I-D only, needle valve kit is also removed. :P I'm considering modify PPIC, i.e) add adjustable kit like this. If this works well, PPIC cylinder volume can be adjustable or on-off.
Can't tell much from your pic. I have the parts that would allow me to switch the PPIC in & out of the mix but haven't bothered to install them as I'm preferring just the I-M at the moment.
LMWDP 267
wachuko
#6530: Post by wachuko »
Cecvin wrote:Got my set up goin this weekend! So far so good. First shot pulled was nearly perfect! Beautiful machine.
Love that cup washer!!! I am going to borrow that idea and will add that to my wish list for when I get to redo my coffee bar area.
Great setup. Thank you for sharing!!
Searching for that perfect espresso!
Wachuko - LMWDP #654
