PID display failure on Izzo Alex Duetto II
So I just received my third PID unit from Chris Coffee. The original (blue) display from January 2012 started losing segments after a year or so. Replaced with the newer (red) model from Chris Coffee in February 2015. The replacement starting losing segments in April 2016, more as time goes by. I have another replacement, but before I install it, any thoughts on what's going on? Is heat the problem, and is there anything I can do to insulate the PID unit?
The problem, I believe might well be the voltage control unit. on a lot of early PIDs, where the onboard transformers fail, I out-boarded a replacement transformer and put a small resistor in to drop the voltage a tad, this seems to help keep the displays working and prevents other failures..The PID works fine at a slightly lower voltage.
Hmmmm...I wonder if this is why I've had to replace my brew boiler temperature sensor 3 times (~5 yrs ownership, iirc).
LMWDP #748
- BaristaBoy E61
Have you spoken with anyone in service at Chris'?
I doubt it has anything to do with the transformer, if the transformer fails everything goes down not just one or several segments of the display. I suspect it's cold solder joints on the circuit board. That's where I would check first if you're competent enough with a soldering iron and know what to look for. If not - DON'T DO IT!
UNPLUG THE MACHINE FROM THE WALL FIRST!
Yes, I emailed back and forth with a tech at Chris Coffee, and they graciously sent me a new one this time. They don't know why some of the displays fail, but said it happens to about one in twenty. I guess I'm just lucky that I've had two fail!BaristaBoy E61 wrote:Have you spoken with anyone in service at Chris'?
I don't know anything about soldering, so I'm not going to mess with that, but thanks for the suggestion. Sounds like a quality control problem at the manufacturer.
- BaristaBoy E61
"I guess I'm just lucky that I've had two fail!"
You're luck you chose Chris' Coffee Service - They're simply 'The Best'!
- Portlandia
I wondered why Izzo decided to change the nice blue read out to red, when Vetrano decided to do the opposite. I find the blue much more appealing to my senses and a calming presence in the morning.
- BaristaBoy E61
I believe it's because the red LED display is more tolerant to higher temperatures.
