Owner experience with Bezzera Strega - Page 146
- baldheadracing
The Strega takes almost any E-61-sized screen. However, E-61 screens usually have a blocked center, which is not needed on a lever group (although the stock Strega screen has a blocked center IIRC).
The current hotness for lever groups is the IMS 35 sold by Londinium. The previous hotness was the IMS 200 sold by Cafelat. Both of these are custom IMS screens that have holes in the center. I do not have the Londinium version; only the Cafelat.
Tests by a local lever machine manufacturer
showed that the Londinium version of the IMS 35 had the best-appearing and most even dispersion/shower flow among a bunch of shower screens. However, there was no difference in the cup with traditional roasts vs. the old-school clip-on lever screen (which is used in commercial Bezzera lever groups). The only shower screen that affected taste was the Matrix as the grind size had to be changed. For light roasts, I did a quick comparison between the Matrix vs. the Cafelat IMS 200: The Matrix Shower Screen and, as a result, kept the Cafelat IMS 200 in the Strega.
- mrgnomer
bostonbuzz wrote:Which screen did you use exactly? I was under the impression that they wouldn't stay in place so I wrote them off. I'd like to try one.
I used the IMS ACC-E61-NT-SS Nanotec showerscreen. I haven't had a problem with it. I put it in with a Cafelat 8mm grouphead gasket. That I did have a problem with. My open portafilter doesn't lock in all the way and popped out from time to time. Next time I take everything apart I think I'll sand it down a bit.
Kirk
LMWDP #116
LMWDP #116
baldheadracing wrote:Tests by a local lever machine manufacturershowed that the Londinium version of the IMS 35 had the best-appearing and most even dispersion/shower flow among a bunch of shower screens. However, there was no difference in the cup with traditional roasts vs. the old-school clip-on lever screen (which is used in commercial Bezzera lever groups). The only shower screen that affected taste was the Matrix as the grind size had to be changed. For light roasts, I did a quick comparison between the Matrix vs. the Cafelat IMS 200: The Matrix Shower Screen and, as a result, kept the Cafelat IMS 200 in the Strega.
So based on your experience you suggest this one as best for Strega? https://www.cafelatstore.com/products/ims-screen
And it suits stock portafilter well?
PS my machine and group is of course levelled, checked using my iPhone level app
- baldheadracing
I'd suggest figuring out your issue first before spending money.brz wrote: So based on your experience you suggest this one as best for Strega? https://www.cafelatstore.com/products/ims-screen
A new shower screen won't change anything unless there is an issue with your current screen. As Kirk suggests, the first thing to do is to remove the screen and clean it. Coffee oils/residue do build up on the top of the screen and cleaning would be what I would do first.
I would suggest marking the orientation of the screen before you remove it. Then you can change the orientation of your screen when the screen is re-installed. If the dispersion pattern changes to match, then that would be the only reason that I would change the screen.
Finally, I now realize that I wasn't clear in my previous post. To clarify, I don't think that the screens would make much difference, if any, in the cup. The various IMS 'precision' screens - 35, 200, nanotech, high dose, etc. - were each designed to help address or solve specific issues that arise in commercial use. If you have one of those issues, then the appropriate screen can help. If you don't, then buy a bag of coffee instead
Small Teaser of a simple mod to control PI pressure using an adjustable pressure reducer behind the pump.
I will share more detail in the future.
Hi All
Got a bit lost in this long Thread.
After 8-9 years it's time for a full lever/group head maintanance (ther is a bit of a lick and the Lever doesn't really goes all the way up).
Did anyone posted some instructions here for that (maybe including all the parts/orings needed for that).
Thanks!
Thanks!
I have had my Strega for one year. I recently decided to remove the piston to clean and lube the seals. I'm happy to report that all went well!
The only catch was figuring out how to deal with the metal conduit that carries the wires for the microswitch. I discovered that the conduit will remain in place as the piston and spring assembly slide straight up over it. Be sure to pull through some extra wire from inside the machine to allow this.
Here are the instructions I followed: Another Bezzera Strega Lever Lube Job!
When it comes time to replace seals I will look at the Cafelat silicone options. Maybe someone can give specific advice as to which ones.
