Owner experience with Bezzera Strega - Page 143
I've read a few times people mentioning that it is annoying to open the Strega up. Particularly, there are a couple screws that are hard to access because of the weird angle. It is actually quite easy with the correct tool - a 'wobble' hex key. They allow you to work like this:
Sorry the image rotated, idk wtf its doing.
So I recently got a Strega, and it hasn't gotten much care for a while. I'm just getting started with cleaning it and noticed both heating elements in the group are very loose. They sit where they should, but there is basically nothing holding them in, and they have plenty of radial movement, so I image they are in poor thermal contact with the group. Is the solution to just squeeze some extra heat sink compound into the holes, squeeze the resistors back in, and goop some silicone on top, like they originally were?
Next question - this machine likely hasn't been descaled in several years. I bought some descaling powder (https://www.world4trade.de/Scale-Clean- ... kalker-1kg). The instructions say it can be used at 5% to 20% concentration, with 10% recommended for routine descaling. They also say that it can be left in the machine for 1 to 8 hours. Is there a recommended approach for an machine like this? Multiple gentle treatments, or should I just hit it with 20% for 6 hours?
- baldheadracing
FYI, I just checked my group heating elements and they don't wiggle at all. I have no idea how they are held in.
For descaling, I use a borescope - ones that hook up to your phone are very inexpensive on eBay, Amazon, AliExpress, etc., - and take off a fitting and look into the boiler. Some phone cameras also work. I'm going from memory, but I think that I removed the vacuum breaker pipe/fitting, but it could have been the steam wand; I can't remember. That way you can descale as little as possible - and know if descaling is necessary, and when to stop.
It looks like you have an older machine with has an uncoated copper boiler. (The production date should be on a sticker on the boiler.) With uncoated copper/brass, I prefer to descale as little as possible. I also like to keep the protective black oxide that should be coating the copper intact.
I've never used sulfamic acid for descaling so I can't help with that.
Good luck!
Good luck!
Thanks for the tips! Yes, the machine is older. I will check the dates, but its maybe 8-10 years old?
I have an itch to remove the heater coil from the boiler, to look inside. Is that a bad idea? I have an extra seal.
- baldheadracing
For me, the borescope/phone camera is a lot easier than the heating element. It is typical for threadlocker to be used to secure the element, but I've never removed the one in my Strega so I don't know.
The usual way shops take off a heating element is with an impact wrench/gun. A cordless impact should be plenty powerful.
Heater looks to be thread locked on mine. I removed the water level probes, and they had some scale, but maybe a normal amount, nothing crazy. I saw your borescope vid you did a while back, it looks good! I just don't know if I can justify spending 40$ on a tool I use once.
Any tips on why there is lots of air coming out of the hot water wand? I get a second of only water, and after that it starts sputtering a lot. Plenty of scale particles coming out too.
- baldheadracing
Borescopes that use your phone as a display are about 10 Euro on amazon.de ...
Offhand, steam coming out of the hot water wand sounds like the boiler water level might be too low. Note that there is an upper and lower water level - maybe they are switched?
Manuals and wiring diagram: https://wiki.wholelattelove.com/Bezzera ... nd_manuals
I see they can be quite inexpensive, but I didn't really want to risk it going straight in the trash. I guess they are okay?
About the probes - yes, they may be switched. I noticed the position of them in the drawing, and mine are reversed. I assumed that was okay, but i guess I should check the wiring. It definitely sounds like the water level is too low.
- mrgnomer
Bezzera likes to use loctite. Heat the threaded connection for a bit to soften the loctite then lean in a bit with some torque to break it free. I had to to that with the lever and portafilter handles of all things to break them free when I switched to wooden handles.
If it's the heating element an impact wrench or breaker bar should do the trick. They're notoriously tough to break free.
Kirk
LMWDP #116
LMWDP #116
