My Slayer single group - Page 2
It wasn't anybody, in particular, just older forum posts!CarefreeBuzzBuzz wrote:Sounds about right on the maintenance. I don't know who told you that slayer is not responsive but they are actually quite excellent. They have online videos for owners only of repairs. I believe they have been top knotch.
I just followed the manual. I think I am at 44g right now?JackHK wrote:Congratulations with the new baby
Can you help tell me how much flow in 30 sek, when your paddle is in max position to the left ?
I have e61 dual boiler there give 225 ml in 30 sek, another e61 dual boiler give 425 ml in 30 sek and old Oscar give 404 ml in 30 sek
- CarefreeBuzzBuzz
JackHK that is the pre-brew setting (paddle half-way) that NG posted. One would have to measure the output to get what you are asking.
I just measured my Slayer at full brew position. I get ~245g in 30sec.
Cheers,
Dave
Cheers,
Dave
Thank young wrote:I just followed the manual. I think I am at 44g right now? image
Perfect, thank youdynamiteid wrote:I just measured my Slayer at full brew position. I get ~245g in 30sec.
Cheers,
Dave
Hey Dave, this is a helpful data point to compare to other owners, thanks! Mine only measures 214g in 30 seconds (at 19% pump pressure, 3 bar inlet pressure). I think the value depends on quite a few factors including the temperature of the brew boiler (in my own anecdotal testing, flow rate can change a bit with a change in temperature). Can you share your pump power % and plumb pressure values?dynamiteid wrote:I just measured my Slayer at full brew position. I get ~245g in 30sec.
Cheers,
Dave
- BaristaBoy E61
Zanderfy wrote:Hey Dave, this is a helpful data point to compare to other owners, thanks! Mine only measures 214g in 30 seconds (at 19% pump pressure, 3 bar inlet pressure). I think the value depends on quite a few factors including the temperature of the brew boiler (in my own anecdotal testing, flow rate can change a bit with a change in temperature). Can you share your pump power % and plumb pressure values?
I don't mean to hijack this thread Alex but you're setup has me intrigued. Would you please explain the 'apparatus' you have installed in 'Deep Throat' (K30 Vario) to single dose?
Thanks
My pump pressure is at 24%Zanderfy wrote:Hey Dave, this is a helpful data point to compare to other owners, thanks! Mine only measures 214g in 30 seconds (at 19% pump pressure, 3 bar inlet pressure). I think the value depends on quite a few factors including the temperature of the brew boiler (in my own anecdotal testing, flow rate can change a bit with a change in temperature). Can you share your pump power % and plumb pressure values?
Dave
