Moonraker workflow improvement
Espressmyself
#1: Post by Espressmyself »
Just changed my Moonraker workflow. After placing the grounds into the portafilter, I now use my OCD distributor first to essentially flatten the puck with only 1-2 spins - this eliminates the grounds accumulating on one side of the portafilter and even the telltale ridge. I then use the Moonraker for 6-10 slow semi-spins, then tamp. Results are consistent, channeling is minimized and the distributor only adds about 5 seconds to the puck prep time.
