after three days of usage I can say I will never regret getting the Elizabeth.
I can make a very fine Espresso and Cappuccino with just some adjustments to the PI and temperature and shottimer.
Now I'm having much better Cappuccinos as ever before.
I use atm the Mokaflor Oro Espresso, that I got as a gift.
Tho maybe not the best, but even this makes a nice cup.
Lelit Elizabeth Owner Experience - Page 21
I am about to purchase Elizabeth as my first serious espresso machine however am confused about the preinfusion settings. Can the preinfusion time be altered in either shot type? ( steam pressure pre-infusion and bloom phase ). For example, can you prolong the bloom phase from 12 seconds to 20 if you wanted to?
Thank you
Thank you
There are in depth video reviews on Dave Corbey youtube page, it explains all you need to know about different settings and how to set it all up etc etc.
Good luck.
Good luck.
I've had my Elizabeth for almost a month now (V3 purchased from Clive) and am very happy with the purchase. Excellent build quality, relatively quiet, beautiful machine. Some of the more advanced features described in this thread really shine through (including the real-time temp check for the steam and water that I believe was just introduced in V3), and excellent steam quality. Very impressed, very happy!
Sooo excited! Our Lelit Elizabeth V3 has just arrived to join our Eureka Mignon Specialita grinder and replace our 8 month old Breville Barista Express
I am very happy with my choice, it is the perfect look for our Kitchen and I love the style over the standard e61 style look machines. Thanks to this thread for the wealth of info that helped to make the decision as well
With our local roaster beans of choice, I have had to dial the Specialita right down to 1.5 or so to get the flow correct. As of now I am running 18grams in the double basket with about 33grams out after 28/30 seconds with the standard 6 seconds of pre-infusion using button 2 on the machine. The coffee is more bitter than the output of the BBE. I queried the roaster about short or long pre-infusion and he mentioned they don't use it on their commercial machine in their espresso bar.
Maybe its running a little quick and I need to slow the shot down even more?, but also wondering about adjusting pre-infusion length as well.
I guess this machine is such another level than the BBE, im asking for any thoughts to get a better result please
Yep, don't underestimate the power of pre-infusion on the required grind to get your flow rate target. From my experience with a BBE, for example, 6 seconds of manual on preinfusion with that machine is a LOT less water than 6 seconds of preinfusion on the Elizabeth (although some of that will be controllable by how hot you have your steam boiler).greminn wrote: Maybe its running a little quick and I need to slow the shot down even more?, but also wondering about adjusting pre-infusion length as well.
Try 0, 2 and 4 seconds of pre-infusion and see how much that changes your grind size requirements. A grind that gushes at 6 seconds can absolutely choke the machine at 2 and especially 0. I generally find 4 seconds of pre infusion for medium blends to be pretty solid.
Many thanks for your suggestion. This has made a good difference (at 2 ATM), so will now start to play around knowing the variables. Cheers!hercdeisel wrote:Try 0, 2 and 4 seconds of pre-infusion and see how much that changes your grind size requirements. A grind that gushes at 6 seconds can absolutely choke the machine at 2 and especially 0. I generally find 4 seconds of pre infusion for medium blends to be pretty solid.
