Lelit Bianca Warm Up & Recovery Time - Page 2
A couple other things to add in case this might help others...
- I found it surprising that a solid state relay could fail in this way...reduced voltage on the output rather than stuck on or stuck off.
- Apparently solid state relays can get very hot and based on the metal backing, I assume they need to be in direct contact with the frame of the coffee machine which acts as a heat sink.
Looks like I could have ordered this elsewhere for half the price. Still happy to support Jim and 1st-line!
In case anyone else has a problem with their SSRs on a Lelit Bianca, the manufacturer's part number is RF1A23M25. It took a while to find someone I could order from in the US who had it in stock and would let me order just 1 instead of 10. Below is a link to what I found in case it may help someone else.
https://www.onlinecomponents.com/en/car ... 01728.html
One long term suggestion, if you're getting that much scale, maybe move to filtered water (something that drops your hardness)? I have a plumbed in setup but an everpure is cheap to set up for that, it was under $80 USD on amazon. Even an RO is pretty cheap if you're manually filling and you can use it for drinking water too.
Thank you. I only went down the scale route since others had suggested that might be the cause but after pulling out the steam boiler heating element I could see there was virtually zero scale in the boiler or on the heating element. I'm using a BWT Bestmax Premium filter.
