Lelit Bianca User Experience - Page 76
- slybarman
Amazing latte art. I'd like to sign up for lessons!!!
Julia
- slybarman
Ha. I'm a one trick pony and only take pictures of the ones that come out ok. There are plenty of blobs that never see the light of day, though still taste good.
I just found this this morning:thusband wrote:There's this one but it would have to be reworked a bit. https://www.harborfreight.com/2-inch-mi ... 97217.html
I've been looking for this one I've used on my La Pavoni for several years but can't find where I got it. It has a magnetic base with a couple of jointed arms and small mirror. Certainly not as nice looking.
https://www.amazon.com/Ullman-S-2X-Mag ... 574&psc=1
It should arrive tomorrow for use on my "Slayed" BDB, we'll see how it works.
LMWDP #583
Hey, how often do I have to change the Lelit water filter (MC747)? Only every 35 or 70l (depending on the size) or should I also change it after some time - even if i didnt reach the 35 or 70l (like after a month)?
Hello! I'm a new Proud member of the Lelit Bianca. I have had it for a week now and A weird noise has started to annoy and worry me. Whenever I start the espresso brewing a weird noise appears. The more open the paddle is, the more noise. Usually the noise fades away after a few seconds. If I turn on the brewing with the paddle closed and then open it, there is no noise. The manometer vibrates when there is a noise. Does anyway have any idea what could cause this and how to fix it?
With the paddle to max With the paddle closed and the opening.
- slybarman
The bouncing pump pressure gauge is a bit odd. Could something be blocking the water intake in the reservoir? I assume the machine is not plumbed in?robban39 wrote:Hello! I'm a new Proud member of the Lelit Bianca. I have had it for a week now and A weird noise has started to annoy and worry me. Whenever I start the espresso brewing a weird noise appears. The more open the paddle is, the more noise. Usually the noise fades away after a few seconds. If I turn on the brewing with the paddle closed and then open it, there is no noise. The manometer vibrates when there is a noise. Does anyway have any idea what could cause this and how to fix it?
video
video
slybarman wrote:The bouncing pump pressure gauge is a bit odd. Could something be blocking the water intake in the reservoir? I assume the machine is not plumbed in?
I checked and there is nothing in the reservoir except the stock filter. I tried with and without filter with the same result. However I did notice that there are air bubbles traveling in the tub from the reservoir to the tank. Is that normal?
- slybarman
I'm not positive, but I wouldn't think so. Maybe air is making the pump cavitate. Check the hose for any kind of crack or split that could be letting the air in.robban39 wrote: I checked and there is nothing in the reservoir except the stock filter. I tried with and without filter with the same result. However I did notice that there are air bubbles traveling in the tub from the reservoir to the tank. Is that normal?
