Lelit Bianca User Experience - Page 61
- Misiak
I haven't read such reviews neither. Jim, could you post a link? I'm quiet interested because I found the brewhead is very hot even in standby mode. I meassured the power consumtion and it's around 1KW per 24h which is great. Theoretically this machine can run 24/7 without significant power bill increase.
Lelit Bianca PL162T - Niche Zero
- slybarman
I have standby mode turned off and have a smart outlet that turns the machine off after my coffee time, so didn't have an opportunity to observe anything hinky about standby mode. I really like using the smart outlet for turning the machine on and off on a schedule or using my phone or voice commands to Google.
- another_jim (original poster)
Nor can the group itselfPeteB wrote:I couldn't see how the group-head could possibly rise in temperature 25-odd degrees to a stable temperature in only a matter of minutes.
Jim Schulman
- slybarman
This morning I turned my Max pump pressure down to about 9.5 per Jim's post. I wish I had done it weeks ago. Much better. Much easier to hold around 9 bars during the shot and better control of the range under 9 bars.
- Misiak
This is with paddle fully off? I have 10 bars now (was 11 from factory) when fully open and 10.5 bars when off.
Do you guys know what TrR means in shot counter? U have 200 TrR and 206 ToT ?
- slybarman
Trr is the temporary resettable count, the other is the permanent non resettable.
In your case 6 shots were pulled and then the temporary was reset.
- Misiak
Thanks, didn't know that. But I didn't reset the counter at all and had a brand new machine. Could be the 6 shots are coming from the factory ?
- slybarman
Probably 1st line or the factory. They test the machine before shipping.
- PeteB
I did the same... turned down the max pressure. But then found that if I ran a slow preinfusion with the paddle at around the 7 o'clock position waiting for the pressure to build to around 2 bar before opening the paddle fully, I was then only able to obtain a maximum of around 8 bar and then falling away for most of the rest of the shot. I haven't worked out whether or not that is important or not yet as I'm still juggling with a number of variables. Temperature being one. It looks like I' settling on an offset of around 12ºC up from the factory 10º for my machine.slybarman wrote:This morning I turned my Max pump pressure down to about 9.5 per Jim's post...
PeteB
- PeteB
I'm trying to figure how you get a higher reading with the paddle closed that when fully open. Am I understanding you correctly?Misiak wrote:I have 10 bars now (was 11 from factory) when fully open and 10.5 bars when off.
I assume you are taking these readings with a blind filter-basket?
PeteB
