Lelit Bianca User Experience - Page 55
- Misiak
Hi everyone, can someone tell me where I can find plumbing info for Bianca ? I can't find this info anywhere. What's the size of the adapter on the water line ? I think one side is 1/2"M but not sure what's the other side. Thx
Lelit Bianca PL162T - Niche Zero
Please see my post 2 or 3 pages back. The adaptor is 3/8 to, I believe 1/4. The hose that the machine came with we'll connect to the underside where the water tank connects. Then you can connect to the other side to whatever you want. That could be a John guest style fitting, or depending on if it's close enough, you may be able to connect to directly to your water filter regulator.
About the paddle tuning ,,I would advise caution , the allen set screw is only a 2mm and quite fragile , certainly not hefty enough to be unscrewed and reset repeatedly numerous time -- it will strip easily ,,as will the very soft brass insert in the wood paddle ,,Lelit could have made those parts more resistant to manipulation . Lelit could also have made the needle valve stem larger in diameter .
My Bianca came with that 2m set screw already stripped ,, Lelit ended up replacing the paddle and set screw. Not for no reason that upon purchasing the aftermarket kit from Lelit it comes with not one but two needle valves ,,obviously Lelit is expecting the needle valve to be a consumable item.
My Bianca almost complete 2 weeks and I found those the most exited weeks, more turns play with the paddle the more coffee secret appear to be understood, variety of different coffee the more flavors are been discovered.wesleynance wrote:Just received my Niche grinder yesterday. My birthday present this year (last year was my Bianca!) Any tips or tricks to getting the most out of these two when used together?
As long as I roast my own coffee and using single origin which Bianca let me change my way of roasting process.
Enjoyed every moment til now.
Abdullah Ahmad
Hi everyone,
I'm a new entry, I'm Cristiano and I'm an "Italian Coffee Lover"... I live in Milan, near Lelit headquarters, and today I've received a new Bianca and William PL72 grinder.
My english level is poor, but step by step I can read all pages of this interesting thread.
Thank you in advance for your previous experiences with Bianca, I hope to return the favor.
Have a nice coffee!
Have a nice coffee!
Lelit Bianca PL162T - Lelit William PL72
