Lelit Bianca User Experience - Page 212
- slybarman
I am using this one in 58mm.
forgot to mention that it is short to work with the baratza sette.
https://www.aliexpress.us/item/3256802979845985.html
These Sworksdesign funnels work great, magnetic, and can be purchased in various heights...in case you're a vigorous WDT'er like me.
https://sworksdesign.com/Seamless-Magne ... p432524031
Nice...if I pull the trigger, black is the way I will go too! Did you Bianca replace another machine?
Let us know how it goes for you...
Yeah they do look great in black, shame they charge such a premium for it !!
I had a version 2 Bianca in 2021, then had an acs Evo leva, and the V3 replaced that
Main reason for me were
Bored and wanting a change
Gear pump noise, Im very sensitive to sounds
Warranty
Warranty
I'm using the Normcore magnetic with my Elizabeth, but it the same portafilter the Bianca comes with. I would say whatever you bought originally was the issue, not that the Bianca has some odd portafilter.
Just a guy making his wife coffee to justify a hobby.
Are you using the Sette 30 or the 270/270Wi? The latter have very wide adjustment range for the fork that holds the portafilter from the top.slybarman wrote:I am using this one in 58mm.
Day two of the Bianca
Upped the dose to 19g, setting 7 on the duo
This is an anerobic el Salvador light filter roast from
https://www.papercupcoffee.co.uk/produc ... -anaerobic
Needs a tighter grind
I've also ordered a pullman basket from square mile lol £20 delivered
Been a few yrs since I used both 58mm and flow control so set on automatic low flow for 12s
But tempted to go back to the paddle
What sort of profiles are people using for light roast.
Cheers jake
Cheers jake
- slybarman
Did you find out if this is indeed true?
I've been strongly considering the upgrade from BDB to Bianca for a couple of years... this may be the season!
