Lelit Bianca User Experience - Page 190
- slybarman
It does not have to be removed to get the cam to go back into place, but it does make it easier. i don't remove it.
i believe you need a 36mm wrench
Thanks! Ended up running out to Home Depot and getting adjustable pliers (or whatever they're called)
Some electrical tape to cover the teeth and off I went
Hopefully I did it right. The cam fought me a little bit, but everything is tight and smooth now. One thing that concerns me is that there is about a 1mm gap between the lever and the cam cover. No idea if it was like that before, but everything seems to be tight so I can't imagine it's wrong.
- slybarman
I've not had good luck using adjustable wrenches in terms of scratching the stainless. i broke down and bought a metric service wrench set from harbor freight.
I confirm the gap so no worries therehangry_barista wrote:Thanks! Ended up running out to Home Depot and getting adjustable pliers (or whatever they're called)
Watch that gap when your brewing around 9 bars, you'll see it widen as the spring in there compresses.
Thanks all
Next, I installed the IMS shower screen and Cafelat gasket
The shower doesn't seem to be as dispersed as I thought it would be, and I'm getting a debit rate of 180ml/30 sec - anything to be concerned about here?
The dispersion is definitely something I want to figure out, as I'm getting channeling and dark puck spots even with good puck prep
- slybarman
solution searching for a problem? what is wrong with the stock shower screen?
