Lelit Bianca User Experience - Page 125
Regarding pulling water from the Steam Boiler regularly......
I've noticed since day 1 that my steam water isn't a clear as my grouphead water........very slight brownish color. Does anyone else have that going on? I pull water from it pretty regularly and it always looks this way.
I'm plumbed in with a filter/softener.
Thanks!
Brent
Thanks!
Brent
- slybarman
Yep...if anything, water dispensed from either boiler should be identical. The only way water in the steam water could get contaminated is by failing to purge the steam wand after steaming milk. When the machine is turned off and the boiler cools down it will draw any milk left in the steam wand back into the boiler where it can turn rancid. NOTE: This issue can happen with "any" espresso machine.
Another culprit could be scale deposits which can build up and result in scale desolving into the water. (steam-boiler water is alkaline loaded with minerals.) In either event I might suggest a descaling operation and or draining the boiler and see if it improves.
Krups, then Silvia, then Livia 90, then a Techno! Does it ever end? [sigh]
Many many many folks fail to clean the steaming want properly. It is a common source to gunk finding its way back to the steam boiler.
Regarding the second issue, this is what I'm observing regularly when machine is heating up:thm655321 wrote:I have a couple of issues that have cropped up that I am looking for some advice on solving.
First starting a few weeks ago the hot water want would continue to drip after being used. Not always but some of the time.
Now in addition to that the bottom of the group (not sure what to call it) that spits water and steam for a bit while warming up continues to spit water and steam when at temperature and full pressure of the steam boiler (pic below).
Any ideas on what I should do to solve those?
Thanks in advance.
During heating the water is dripping from it and some steam is coming out thru the knob. This stops when the machine reaches the temperature. I assumed it's something normal, but now that you say to inspect things I started to wonder - is it normal?
When is this knob expected to give water / steam anyway?
I reassembled the group a few times, but it's still very stiff. However, I'm no longer worried about the spring noise. I got to try another bianca and it sounds the same, just operates more smoothly.
I can't spot any obvious misalignment issues, to me it looks just as the images from the tutorials. How does it appear to the more experienced eyes?
This is normal during heating. It's coming from the anti-vacuum valve. It should stop once the machine is up to temp, and the valve closes. If it does not, there might be something blocking the valve from closing. The usual suspect is scale.homie wrote: During heating the water is dripping from it and some steam is coming out thru the knob. This stops when the machine reaches the temperature. I assumed it's something normal, but now that you say to inspect things I started to wonder - is it normal?
Hi everyone.
I read dozens of pages and didn't quite find an answer to my question, so I'll ask it here.
- I'm using the resin filter. The rubber holder sits flush on the bottom of the reservoir. Just curious how this works with the filter, because in the rubber holder wouldn't this restrict proper flow to the filter? Not sure if that makes sense.
- I've had my Bianca for a couple of weeks, and in the past few days I'm getting a weird noise when pulling shots. It sounds like a vibration, louder when it's getting water from the reservoir. Any known issues here? I can post a video if that helps.
- slybarman
Do you have yours set up and installed as shown? It should sit slightly off the bottom. If it isn't, I would slide it up slightly in the ring that holds it. The pump will run slightly louder on mine the first pull after I fill the tank. Air invariably gets into the line and the pump cavitates until the air is pushed out.
Yes, it's like that. Though I set the filter a little lower where the feet protrude from the bottom a bit.
Wouldn't the rubber support sitting flush to the bottom inhibit the water flow? Seems like a very intentional design of course, so perhaps that's a silly question.
