Lelit Bianca setup problems [Solved]
Hey everyone,
A friend of mine got a Lelit Bianca since I praised it. I had mine for roughly 5 weeks.
The problem: he just started the machine startup procedures. The machine's reservoir is full and his brew boiler has been filled. However he ran in to problems at step C.5 (page 14): When the LCC instructs the user to lower the lever. The machine somehow does not register the lever being lowered. The screen keeps displaying lower the lever even if it is already lowered. We even tried to reset the machine by holding (+) when its off then switching it on. It went through all steps but it got stuck again. This halts any heating up. This is an unfortunate first impression for my friend.
Hoping to find solutions. Thanks!
Update: machine replaced by distributor.
Is the roller switch behind the lever stuck?MG wrote:Hey everyone,
Was just an idea. It doesn't seem stuck. My switch looks the same as in the pictures. If the pump starts and stops with lever action then the switch is fine and the signal is evaluated by the control.MG wrote:Water does come out of the group head when the lever is raised and stops when lowered.
- another_jim
He probably needs to call the techs at his vendor to seen if they've have seen this glitch before. I had a glitch on start up (can't rememebr precisely where), it went away when I unplugged and replugged the machine (I think the PID panel stays powered on unless you do that).
Jim Schulman
Update: machine replaced by distributer. No more problems
Followed this advice. Thanksanother_jim wrote:He probably needs to call the techs at his vendor to seen if they've have seen this glitch before. I had a glitch on start up (can't rememebr precisely where), it went away when I unplugged and replugged the machine (I think the PID panel stays powered on unless you do that).
