La Pavoni Eurobar De Luxe (EDL) 1999 refurbishment - Page 2
espressoresourcenw
Postby espressoresourcenw » Apr 15, 2019, 3:57 pm
renburanto wrote:Thanks, I tried that and not all came out. It is really stuck in there. I think I'll be getting an M6 die/tap and tapping it again. Might try to re-thread the pipe and see if the Pavoni springs back to life. Then some time in the future order a new pipe to replace the old one.
What will happen if the pipe is shorter than the original one? Will less liquid come out?
Shortening the pipe will impact thermal stability, because the water would be flowing from further away from the heating element, and may in fact not flow past the heating element at all if it is very short. I have a spare pipe which I scavenged from a Saeco Aroma boiler; it should fit. It is 51mm long, including the threads. I would be happy to send it to you for the price of postage if you still need one.
Regards,
Joe
Espresso Resource NW, Inc.
service@espressoresourcenw.com
