La Marzocco Linea Mini User Experience - Page 154
That is a GORGEOUS machine!Howard Alan Treesong wrote:image
I have the low profile legs and rail from Pantechnicon. I considered the 50mm, but the 25mm appear more in balance.
I have the 25mm legs from Pantechnicon as well. they suite the machine IMO.
** beautiful machine !! love it
Hey! In researching how to maintain my linea mini, I read how, for dual boiler machines in general, it is important to purge the steam boiler through the hot water spigot to avoid scaling. Since the brew boiler is fed from the steam boiler on the Linea Mini, so I still have to do this?
Yes, you should still drain your steam boiler through the hot water spigot every month or two. Minerals will still build up in the steam boiler so its best to flush it every so often. Turn off your Line Mini, then empty the boiler into the drip tray.
Turns out my leak from a few weeks back was a leaky fitting in front of a check value. LM repaired under warranty and all is good now
(Not sure if this should be in a separate thread?)
I've just noticed the New Zealand price for a new Linea Mini has gone up quite a bit from NZD$6,649 to $7,935 ($1,286 increase) .
Looking at Espresso Ninja it looks like the expensive version has the Pro Touch steam wand, but that's only $700 separately so doesn't explain the change.
Did they just put the price up and include the steam wand?
Is this just in NZ or elsewhere?
Glad I got mine earlier in the year!
- Jaroslav
Is it working for you? I don't see any updates so far.PForPho wrote:Looks like the new app is finally being released!
Jaroslav
Don't have the update on my end yet, must be rolling out slowly.
