La Marzocco Linea Mini Cup Tray Sound Deadening
I wanted to see if anyone had success with adding some kind of sound deadener to the cup tray on the Linea Mini. I am not sure what (if anything) is considered best in regards to heatproof, aesthetics, and safe for the machine. Any thoughts?
Thanks!
Thanks!
- Supporter ❤
Good luck with that. Many people tried many things; however, nothing fixes the rattling like outboarding the pump. I did that last year and i'm never going back.
If Sorbothane tolerates heat long term, then pieces under the drip try in the corners probably would work. Just don't know if it's properties are change with heat, etc. probably info on line about this. Maybe others here have tried or know a better material.
Cork sheet, bits trimmed and strategically placed. Cork actually holds up very well.
I have used this on several cars, espresso machines and grinders with great success.
https://www.summitracing.com/parts/SUM-879006
This would need to be installed on the underside of the heat tray panel though.
Sugru in the corners https://sugru.com/about . Felt feet around the perimeter.
