La Marzocco Linea Mini 0.6mm gicleur and bar pressure
With the linea micra having a .6mm gicleur, It makes me want to update my Linea Mini with a .6mm gicleur.
I read the other thread about how to do it and I read all the posts too. I am under the impression that I have to lower the bar pressure if I do this mod on the Mini? If so, how come the bar pressure can be 9 on the Micra with the same .6mm gicleur
- another_jim
Whatever gave you that impression is wrong. In terms of machine operation, the pressure can be anything you like, regardless of gicleur size. Your taste preferences is another story; a lot of people prefer setting fixed pressure rotary pump machines at around 8 bar, rather than 9. This preference is based on taste, not operability.linuxAndJavaScript wrote:I am under the impression that I have to lower the bar pressure if I do this mod on the Mini?
Jim Schulman
I installed the .6 gicleur, before I started using my Mini. My pump pressure was about 9 at that time. I ran it at 9 for several months, don't recall when I changed it. l'm currently running it at about 7. I've changed the pressure periodically based on the beans I am using. Don't think the .6 gicleur, which is standard on the GS3, requires a lower pressure. Some users just prefer the lower pump pressure to improve extractions, or for other reasons with or without the gicleur change.
- HB
- Admin
In the future, I suggest creating one thread on a topic area rather than several closely-related threads:linuxAndJavaScript wrote:...I am under the impression that I have to lower the bar pressure if I do this mod on the Mini? If so, how come the bar pressure can be 9 on the Micra with the same .6mm gicleur
- Question on the size of gicleur and grind setting
- How accurate is the bar pressure gauge on La Marzocco Linea Mini?
- And now this one makes three.
HB wrote:...I recommend treating the reading as "X", adjusting X-1 or X+1 bar, and deciding which produces the best tasting espresso.
