La Marzocco GS/3 Sometimes Reboots with Tea Button - Page 12
- AssafL
Is it connected to the scope? If so it is a 1 or 10 Mohm input. That might be sufficient to pull an input low (or high).
- AssafL
Oh - and you may want to disconnect the cables and just watch the reset line. If it returns to resetting - you'll know that the issue is CPU (power supply or similar) issue - but if the line switches - it is a schmitt trigger issue.
- Jake_G
Agreed.Peppersass wrote:I do think there's a chance that you inadvertently fixed a cold solder joint when you attached the leads. Cold solder joints can cause all sorts of random symptoms, including intermittent voltage sags. Could be just a tad of temperature increase/decrease or vibration that makes it happen.
Fingers crossed that this is indeed the case.
Negative. Just 6" lengths of 22ga jumper wire.AssafL wrote:Is it connected to the scope? If so it is a 1 or 10 Mohm input. That might be sufficient to pull an input low (or high).
Good call. The reset line can be watched through the ATE connector, without using any test points. I'll pull the test leads when I get a chance and see what happens.AssafL wrote:Oh - and you may want to disconnect the cables and just watch the reset line. If it returns to resetting - you'll know that the issue is CPU (power supply or similar) issue - but if the line switches - it is a schmitt trigger issue.
Cheers!
- Jake
LMWDP #704
- AssafL
A resistance is far more likely to stabilize something than the reactance of a short pigtail. (Except at RF)Jake_G wrote: Negative. Just 6" lengths of 22ga jumper wire.
Not that its 100% impossible, just 99.9% unlikely.
So I'd suspect a cold solder joint. BTW - it may be that the cold solder joint is altogether elsewhere and the constant jostling of the board scraped away a bit of corrosion. If that is the case, the issue will return. maybe wiggling the board can get it to reboot?
