La Cimbali M21 ULKA pump noise
Hi
My 10 year old Ulka EX5 pump in my La Cimbali M21 was getting very noisy when running water through it, but it did quieten down when the pump was under pressure when running a shot or back flushing. I replaced it with a new Ulka EX5 vibration pump but it gets noisier (i.e. buzzing sound) when it's under pressure when running a shot or back flushing. When I replaced the pump I also installed new rubber pump mounts so it's not the mounts.
It doesn't seem like any any internal water hoses are touching the metal frame or there are any hose restrictions. It's running water through fine and making nice coffee, but I have been advised that a new pump should be quieter when under pressure, not noisier.
Just wondering if there's a problem with my new pump. Appreciate some advice.
Graham
Graham
- civ
Hello:
Best,
CIV
Please check this link: /search-res ... j927072j15GCM59 wrote: Appreciate some advice.
Best,
CIV
Thanks for the link. Lots of reading material to go through. Will hopefully find the answer in there.
- civ
Hello:
Best,
CIV
You're welcome.GCM59 wrote: Thanks for the link.
Best,
CIV
