Is this trick to fill boilers legit?
Elliot
#1: Post by Elliot » Oct 05, 2019, 7:45 pm
Hey all,
So, I was talking to someone about getting around machines that require plumbing. I don't want to do the water jug thing either. What he said:
"No they don't need to be plumbed. I swap my machines at home all the time. When the machine is switched off and cooled down, it creates a vacuum inside the boiler of the machine. So once the temperature gauge has gone to zero, if you place a jug of water under the steamer wand and open it up it will draw the water into the boiler"
This seems overwhelmingly easy for using plumb-in machines like tank machines.
Anyone ever heard of this?
Thanks!
stuartmac
#2: Post by stuartmac » Oct 05, 2019, 9:06 pm
No, 90% of new machines have a vacuum breaker so that the boiler won't go into a vacuum. Also if if that worked you could only steam, you still need brew water from somewhere.
Elliot
#3: Post by Elliot » replying to stuartmac » Oct 05, 2019, 9:15 pm
Thanks, I should have mentioned that this relates to older machines. We were speaking of machines from the '60s predominantly.
vit
#4: Post by vit » Oct 06, 2019, 3:06 am
Elliot wrote: "No they don't need to be plumbed. I swap my machines at home all the time. When the machine is switched off and cooled down, it creates a vacuum inside the boiler of the machine. So once the temperature gauge has gone to zero, if you place a jug of water under the steamer wand and open it up it will draw the water into the boiler"
I'm using that to top up my Bellman stovetop steamer when needed, so I don't have to open it. Works perfect
