How to unscrew E61 stainless steel mushroom?
I just did this recently on my E61 machine and I don't know what exactly I'm looking at on yours. I followed this video roughly:
What part did you unscrew here? There are two screws on top, on to remove the mushroom and one to take the mushroom apart. The whole mushroom should come out attached to the big screw.
Might also help to know what machine you are working with here.
- Jake_G
That first image shows an internal hex to remove the mushroom. You'll need to measure across the flats and get yourself a hex key that fits. Tough to judge from a photo, but given the typical group cap has 16mm internal threads, I'd wager that its between 14mm and 17mm.jagobear wrote:Thank you for your reply
The stainless steel mushroom design is different
Can't be unscrew by big screw
<img>
U can see the head is different, when I unscrew the big screw, the head will be removed independently
Cheers!
- Jake
LMWDP #704
Thanks Jake
I have bought a internal hex 14mm to unscrew it
I can take it out and check the situation about the group head now
Huh, interesting. Is this an older version of an E61? Have never seen one like this before!
- homeburrero
Newer version, similar to one from ECM Germany. I think they got a German patent in 2015. https://www.ecm.de/en/ecm/premium-technology/bach wrote:Is this an older version of an E61?
Pat
My version is different to that ecm one
It contain two part, the cap, and then the bottom part.
There are smaller thread under the big thread on the Ecm one
Oh interesting, thank you. Had never seen these before!homeburrero wrote:Newer version, similar to one from ECM Germany. I think they got a German patent in 2015. https://www.ecm.de/en/ecm/premium-technology/
- homeburrero
+1jagobear wrote:My version is different to that ecm one
More info and pics related to the difference can be found in this thread: Stainless steel E61 mushrooms
Pat
