How do I polish scratches on mirrored stainless steel - Page 2
Second the vote on Mothers
I just used to reduce the scratches (from warming cups in the tray) on the top of my Silvano with great success.
I can also say I've seen other forums on the topic of cleaning stainless in general, talking about success with headlight cleaners as mentioned above
Good luck!
Good luck!
- Paul_Pratt
That is amazing work. Really well done.Jb3 wrote:I used a headlight restore kit on the backsplash of my old Silvia. It turned the brushed stainless steel into a polished mirror finish. Here's a pic
<image>
How long did it take?
I don't remember it taking very long. The kit comes with gradual sandpaper grits and since you are using a drill for the sanding and polishing there's not much elbow grease needed. I decided to use the kit since I was going from brushed stainless steel to polished. I'm not sure if I would've gotten the same results with just polish.
Thank you. This is quite helpfulundotcom wrote:Second the vote on Mothers
Good luck!
- ash4889
Really nice job.....Jb3 wrote:I used a headlight restore kit on the backsplash of my old Silvia. It turned the brushed stainless steel into a polished mirror finish. Here's a pic
<image>
Could you give me the manufactures name of product, also did you also use an electric buffer with it or by hand?
i've used mothers chrome polish over the years and it works great to give the machine an uplift in shine.
I used the 3M kit with an electric drill.ash4889 wrote:Really nice job.....
https://www.amazon.com/dp/B001AIZ5HY/re ... WCbHKK9H64
- slipchuck
Corded drill will likely do a better job as it can spin quicker
Randy
Randy
I polish metal at work on a macro level (mass spectrometers) and we use something called autosol. German product that looks like a tube of toothpaste. Its worked great for me when polishing the metal bits I work on
