Having around 10 bars while brewing on La Marzocco GS/3 AV
Hello all,
I recently got a GS/3 AV. I have managed to do bleeding from group head, setting valve to have around 12 bars while heating etc.
So, the question is: I am seeing around 10-10.5 bars while getting espresso. I've tried changing dose to have less in basket (from 20gr to 19gr to 17gr) and also having coarser grind as well but it did not change. I have still have around 10-10.5 bars while getting an espresso shot. And I am seeing exactly 9 bars without portafilter while getting some water.
I initially thought it could be because of using VST basket, I also changed basket(repeated the same things, changing dose and grind size) to the ones comes from machine and it also did not make any change.
Is it something normal?
- Jeff
Did you set the pump bypass value to 9 bar, or whatever value you desire for brewing?
No. It is stated in manual as:
Do you think it is not set correctly in factory so that I have to change?
The water pump is factory set at 9 bar pressure.
I could not get a point, if it is the case should not I need to see same pressure in free water flow? What do you think?
- HB
- Admin
The pressure reading from the onboard gauge is not precisely the same as the actual puck pressure since there's a gicleur (orifice/jet) between the gauge's tee and the grouphead (IIRC, there's. ~0.5 bar drop). I would start at 9 bar on the gauge, following these instructions:yasarcanyilmaz wrote:Do you think it is not set correctly in factory so that I have to change?
How to adjust brew pressure of rotary pump espresso machine?
Then adjust to taste.
Did you plumb it in and set your regulator higher than the factory's? If so, then yes, either adjust your pump or your regulator.yasarcanyilmaz wrote:No. It is stated in manual as:Do you think it is not set correctly in factory so that I have to change?The water pump is factory set at 9 bar pressure.
Or if the factory set the pump to 9 bar over inlet and you're feeding it water at three bar, you'll get (up to) 12 bar out of the pump.
But yes, it seems that everything is normal.
I have not plumb it in. I am using it with water tank. I just started to play with pump pressure as described and now I have just started seeing ~9.5 bar in brew time. I need to modify again to see 9.
The point I still could not get is: If it has already set to 9 bars in factory, should not I expect to see 9 bar instead of 10,5 bar in brew time?
Yes, if it truly was factory set to 9 bar, then it would have arrived set to very close to 9 bar.
