Hands on experience with the Eagle One Prima - Page 53
Hi-
I am not sure to have seen the answer nor a clear video about how the pressure knob of the E1P can be used.
Is it possible through the app or the knob, to start the shot with a 2-3 bars pre-infusion and turn up to 6-9 bars after a few seconds, I mean live... just like a pressure flow paddle that can be found on a Lelit Bianca for instance?
It does not sound clear to me what are the possibilities offered with pre-wetting/infusion.
If anyone can help, it would be much appreciated
The pump pressure knob at the bottom of the machine allows you to set the pump pressure and adjust it easily without the need to remove a panel or modify the pump pressure screw. The adjustment isn't suited for pressure profiling or changing on the fly. I would not use it to adjust profiles since the delay in the app's pump pressure reading is not coinciding with what the pump is doing.
Look at a manual paddle machine or something different if you want to have all these adjustments. Keep in mind that sometimes too much adjustment can lead to undesirable results.
I just parted with my machine this week. My next machine will probably be a La Marzocco or maybe a Slayer.
I also just sold my Eagle 1 and bought a GS3 MP.
In comparison, the Marzocco just feels better made, although I loved the design of the Eagle 1.
After failing 2 times in the first 9 months, I just don't really trust the Eagle 1 anymore.
Same happened to me yesterday. NS NA is sending me the fuse shown here. Hopefully, this is just it.
What have you defined as steam boiler setting: setpoint (bar)?
Yes, of the milk steamer. I think the max is 2.6 psi. Whatever is the maximum value. Why did you ask? Curious to know.
