Hands on experience with the Eagle One Prima - Page 37
I got the file from a prima user in Cambodia, seems that after update it solved his 3 way valve opening bubbling issue.
It's inline with your findings of - used puck have some notable changes.
File name - E1GR_1_0_20210506.hex
Got my Version 1.00 update file too and for me it solved several problems. According to VA it includes the following changes:
- power management behaviour improvement
- forced filling after tank/DC swap
- pump bug solved
- tank sensor bug during filling and washing solved
- heating warning light behaviour improvement
- probes offset bug solved
- pump bug solved
Can you share the file with me so I can compare it?
I'm wondering if the file is machine specific (serial number) or it's the same for all.
Thanks
Thanks
I requested the update file directly from VA/NS but they told me I have to request it through the dealer. Because reasons.
I think it's better, as some users are not familiar with tinkering the internals or calibration of their machines.
Post update, my app / prima had a glitch
The boiler temp was set to 2k Celsius, and only after some trouble shooting, I found out I need to reset both my limit switches (both triggered)
After update my temperatures needs to be recalibrated as well. (Offset)
I also received the file via my distributor.111a111sk wrote:I requested the update file directly from VA/NS but they told me I have to request it through the dealer. Because reasons.
So I'm updated as well. The side panel was under a lot of tension, very tricky to put it back.
The pump and valves definitely became less noisy, I don't know how is it possible but I'd say also the shower dispersion looks more even.
But it messed with volumetrics. I had it set to 61ml (with 3s preinfusion) which gave me 18g->37g. After update the yield was 46g. Set it to 51ml and got yield 33g.
Yes the right panel is kinda tight to put back in place
The black box attached to the panel is pressing on to the esp32 on the main board.
How's your temps ? Any changes post update ?
