Group taste test of brew pressure profiling - Page 2
TimEggers
#11: Post by TimEggers »
Its akin to living is Disney Land...(the happiest place on Earth)! :lol:
(thanks Dan) :wink:
Tim Eggers
LMWDP #202
shadowfax (original poster)
#12: Post by shadowfax (original poster) »
Well, I've finished my transcription of the results, which you can view in this published Google Doc.
As I mentioned, when I arrived on Monday with my machine Jon proposed that we use the K30 Vario, given that it's a little more convenient for dosing quickly and consistently. I agreed that this was a fine choice, so we opted to make that switch. We dialed in Jon's GS3 (since mine was still heating up) and found a grind, dose, and temperature that we liked. This didn't take too long. When my GS3 was hot enough, we started trying shots on it (with a 'flat' profile, i.e. gentle rampup since I don't have the 0.6 mm gicleur and then steady ~9 bars to the end) that had been dialed in on the other one. Now, John's offset is a factory offset (~-5.3F IIRC) and mine is experimentally determined with a Scace to be ~-3F. We were unable to get a Scace to benchmark them side-by-side for the test, so we did this by taste. Initially, setting mine to have the same offset-adjusted temperature (so ~2F lower boiler temp) than Jon's yielded shots that were milder and less pleasant. We upped it to have the same boiler temp setting, and after it stabilized there, we pulled, IIRC, 2 pairs of indistinguishable shots. We were really happy with this, particularly me--it's a good indication that I'll be safe hosting any further tests we do at my own place.
As I mentioned before, the tasters were me, Paul, and Jon. We also had a longtime friend of mine, Jeff, though I believe he declined to participate in the IDing that we attempted to do, so his sheet just has notes.
Test Protocol
Jon and I prepped baskets simultaneously (obviously we took turns grinding the shots), enforcing our doses to be within about a tenth of a gram, and using the WDT to level the baskets, particularly after spooning out excess on any shots that dosed wrong. We pulled shots into identical cups (mine was marked on the bottom to ID after sampling) staggered by a few seconds so that the first one of us that finished could call final volume to the other. As our test proceded, we ended up just shooting for the same final shot volume. After we pulled our shots, Jon would shuffle them randomly (out of view of Paul and Jeff), and then he and I would go to the tasting table and Paul would stir each shot, shuffle them himself, and bring them to the table. He would label one of them "A" with a sticker so that we could keep track of it as we passed the pairs around the table for each of us to taste them in turn. In effect, we were all blind at the tasting phase. We would take notes and make our guesses, discuss the shots, then reveal the actual ones.
You can guess my shorthand. P = Profiled, NP = flat profile/'not' profiled. The profile I was using on the 'P' shots was a normal (pretty fast, ~5s) ramp to 9 bars on the onboard gauge, then after about 15s into the shot a gradual decline to 7 bars. Note that this is pretty challenging to do with utmost consistency when you're profiling manual and ALSO trying to watch the shot volume--trying to look at 3 things (time, pressure, weight) at the same time is not something that I can do that well. That said, it seemed to work at least roughly.
Results
After a quick dry run of the test protocol, Jon and I realized that it can be a challenge pulling a shot onto a scale and shutting it off at the exact weight you want. In retrospection, moving the cup away might have worked better, but probably would have shortened the lives of our scales. :lol: In any event, we ran through the first three rounds and were discouraged by how variable the shots were pulling AND tasting. We suspected that Jon and I were prepping differently enough that it was skewing the results, so we had Jon prep both baskets for round 4 (and onwards). On the 5th round, when the shots were still pulling pretty close, we decided to exaggerate the profiling by dropping to 6 bars rather than to 7 by the end of the shot. After the 6th round, we were feeling like we were observing a difference pretty well, but we were getting taste fatigued and indeed a bit caffeine buzzed, so we went to lunch. We returned for round 7, but IIRC it was only me and Jeff tasting for that one--that or Paul/Jon forgot to take notes for the round.
Here's the shot results summary, excerpted:
Note: R4 is where we switched to Jon-only basket prep, and R5 is where we used the exaggerated profile.
And here's the summary of the shot IDing:
Note: Column 2 (A) denotes the result for the first blind shot, and the columns with taster names are their guesses for that same shot. Green means the taster got it right.
Please look at the Google Doc's other sheets for individual notes from each taster.
In the end, I think the first 3 rounds probably ought to be 'thrown out' inasmuch as I think the taste differences we noted were mostly the result of a variation in the pours that was attributable more to different basket prep styles than anything else. The shots were pretty similar, and their small differences were hard to attribute to either method based on our hypothesis. This is why Jon and Paul refused to guess, though you can see their comments in the taste notes. I guessed, and guessed wrong 2/3 times. As I said in the 4th round we decided to eliminate the possiblity of variable barista technique, and in round 5 we also exaggerated the pressure drop for the profiling shots. Between these 2 changes, we all felt like we were getting down to a predictable difference that tasters were willing to guess on, and almost always guessing right. I would have preferred to go another round or 2, but we were all feeling a bit taste fatigued and like we'd had enough.
Conclusions
Paul described the profiled shots as having a 'concentrated vac pot taste.' You'd probably have to try his vac pot coffee to get a sense of that, but essentially I think the common thing we all got was the predicted 'balance shift' in the taste towards either brighter or sweeter. Occasionally the comparative difference was in the absence of a slight bitterness in the aftertaste that was present in the NP shot. There was much less consensus on the 'body' of the shots, and I think this ended up being a poor predictor of shot variation, at least for this test. I am not ready to concede that point, though--remember we were stirring and sharing these shots, so usually tasters other than the first were hardly getting to sip much crema at all, and I think that really calls into question the validity of comparative observations of the shot body.
It's no cut-and-dry test, and it's sure not going to support any kind of rock-solid conclusions, but I feel like my casual observations have held up pretty well to blind testing, and I'm hoping to repeat this process when I can get more consistent equipment.
I'd also add that the blind test could just as easily be an advertisement against spending the money I have on profiling, depending on your level of curiosity. The effect seems more subtle (isn't that how blind testing always goes?), and certainly both machines were producing lots of really tasty shots. Moreover, we're just testing for an absolute difference here, that is a difference given all other variables are held as constant as possible. It's possible that you could obscure the differences we observed entirely by dose/grind adjustment, at least for the coffee we used.
So there it is. Let me know if I've left anything out...
Nicholas Lundgaard
JonR10
#13: Post by JonR10 »
shadowfax wrote:So there it is. Let me know if I've left anything out...
Nice write-up Nick!
The test was a pleasure, and we all got over caffeinated (note to self - next time spit). Good company, good coffee, cool machines...what more could a coffeegeek/Home-Barista ask for?
One thing that made this test feel more satisfying was that we all felt like the result was a consistent and easily discernible difference on the shot pairs that were very close in all metrics 8)
Jon Rosenthal
Houston, Texas
michaelbenis
#14: Post by michaelbenis »
Great pics, great write-up and on-the-spot adjustments, too.
Thanks for sharing.
Mike
LMWDP No. 237
AndyS
#15: Post by AndyS »
Nice job running a cool test and thanks for taking the time to report the results.
It must feel good to change an espresso extraction variable and actually note a difference in the cup. It's more fun when that happens, isn't it? :wink:
shadowfax wrote:After a quick dry run of the test protocol, Jon and I realized that it can be a challenge pulling a shot onto a scale and shutting it off at the exact weight you want.
This I don't understand. Why not use the GS/3 in automatic mode? That way the flowmeter produces shots of the same mass, within a gram or less.
-AndyS
VST refractometer/filter basket beta tester, no financial interest in the company
#16: Post by shadowfax (original poster) »
AndyS wrote:This I don't understand. Why not use the GS/3 in automatic mode? That way the flowmeter produces shots of the same mass, within a gram or less.
Heh, paint us idiots. I've got such disdain for a feature that's so universally derided that I didn't even really consider it at the time--even forgot that you suggested it the day before the test. :lol: I don't suppose I'll forget it for future testing, though...
OTOH, is "within a gram" the best it does? I haven't played with them enough to know how they perform at espresso flow rates. If that's it, we were almost as good ourselves. having a differential of a gram (well, more like a gram and a half) yielded noticeably different volumes between the two when blinding. IIRC Jon spooned off some when the difference was visibly notable.
Nicholas Lundgaard
AndyS
#17: Post by AndyS »
shadowfax wrote:I've got such disdain for a feature that's so universally derided that I didn't even really consider it at the time.
As you know, many of the espresso "fashions" that fall out of favor eventually make their way back: HX machines, dosers, robusta, dark roasts, normales...maybe even FLOWMETERS.
After all, once a barista has dialed in a shot, s/he ought to be able to put the machine in auto mode and let the flowmeter system cut the shots that follow. The common obsession with ending the shot manually comes as much from the barista's lack of skill in reproducing dose and distribution as it does from real need.
shadowfax wrote:OTOH, is "within a gram" the best it does? I haven't played with them enough to know how they perform at espresso flow rates. If that's it, we were almost as good ourselves. having a differential of a gram (well, more like a gram and a half) yielded noticeably different volumes between the two when blinding.
The espresso flowmeters I've seen produce one pulse per half milliliter. So again, your dosing and grooming have to be consistent. But if so, your espresso output should vary only a little more than +/- 0.5g. That's the way it was when I ran my Tricked out Silvia in automatic mode.
-AndyS
gyro
#18: Post by gyro »
Thanks guys for taking the time to do this and to Nicholas for the excellent write up.
Billc
#19: Post by Billc »
JonR10 wrote:It's my house, with Nicholas' machine added to my setup.
If you ever find yourself in Houston, please do look us up! It would be an honor sir 8)
The honor would really be mine! And easy on the sir stuff, I was a Staff Sergeant in the Marines. Trying to think of a reason to go to Houston. Maybe to visit Baker-Hughes. I used to do consulting for them.
BillC
gscace
#20: Post by gscace »
AndyS wrote:Nice job running a cool test and thanks for taking the time to report the results.
I remember Barry sticking up for flowmeters on AC with the argument that if your grind and dose was under control, the flowmeter helped improve consistency, particularly when one was otherwise occupied with things like steaming milk.
Nicholas and John - thanks for the good work!!
General comments - One benefit of profiled systems using a pressure transducer as feedback signal is that they can offer better pressure reproducibility over a variety of grind fineness settings. This improves consistency if minor changes in dosing occur, and decouples the brewing pressure parameter from both grind fineness and dose volume / weight.
Again, nice work. Unfortunately, I see this post sliding down the list of posts in the machines section. I wish there was some archive of such work on this site so that researchy things would not get buried.
-Greg
