Grind difference between two E61 espresso machines...
the Isomac millennium I am trying to dial in is doing something weird
I adjusted the blind pressure to 10bars with Eric's pressure gauge on the head and when I make coffee it goes down to 9 bar. The my other machine an original E61 Faema is at to 9 bars .
Now for the weird part.
If I grind and tamp the same way that I do on Faema with the isomac the coffee comes out to runny on the isomac . I need to grind more fine to get a good coffee . Is this normal or all E61 should react the same .
Thanks
Thanks
yes it's normal. always will be variations between different machines, and even the same model machines since even the slightest change will impact. while you think the pressure may be 9 bar, they aren't exactly 9 bar and 9 bar. and 9 bar vs 9.01 bar will cause a difference in flow rate.
- randomorbit
I'm assuming the Original e61 Faema has a rotary pump and the Isomac has a vibe pump? Not sure about that, but if so I'd think that would make a huge difference in how the machine behaves.
- mohninme
In your case, I see several possible reasons, the first four being machine specific. I probably missed something too.
- water debit/flow rate
- head space
- water temp
- OPV/pump pressure set point
- using the same basket for both tests?
- consistency of puck prep
Michael
This is it. Different water debit means different rate of infusion means different pour times with same grind.randomorbit wrote:I'm assuming the Original e61 Faema has a rotary pump and the Isomac has a vibe pump? Not sure about that, but if so I'd think that would make a huge difference in how the machine behaves.
- another_jim
In addition, the groups are not identical, and their parts are not interchangeable. There are many different manufacturers of E61 groups, and at least three slightly different designs.
Jim Schulman
- Randy G.
re. The original E-61 Faema - Did you use Eric's pressure gauge to set that machine as well? If not then it could also be a matter of the pressure gauge on that machine reading a bit differently from Eric's gauge.
Yes my original Faema has rotary pump set to 9 bar blind filter
The isomac with vibe pump set to 10 bar with blind both set with Eric pressure gage
Same portafilter
The isomac need a finer grind to get the same 25-30 sec
Same portafilter
