Gicleur - 0.6 mm La Marzocco Linea Mini
blondica73
#1: Post by blondica73 »
I'm contemplating of replacing the 0.8 mm gicleur with a 0.6 mm. However, I'm a little confused. Keno in his blog mentioned the L087/GI/6. When i do a google search I see two different versions, the one he shows in the blog and the ruby gicleur. Which one is better? Do both fit the Linea Mini?
How to install a new gicleur on a La Marzocco Linea Mini
Here's one from espresso parts
https://www.espressoparts.com/la-marzocco-gigleur-0-6mm
and one from Clive Coffee
https://clivecoffee.com/products/la-mar ... by-gigleur
blondica73
#2: Post by blondica73 »
I just received an email from La Marzocco's parts department that the L087/GI/6 was replaced with A.5.108.
Niceguy1818
#3: Post by Niceguy1818 »
Do you have a link to the new part? I can't seem to find it.
MikFlores300
#4: Post by MikFlores300 »
The Espresso Parts one you linked to is the one I've used and it works well. As long as your water is good, you shouldn't have trouble.
blondica73
#5: Post by blondica73 »
Niceguy1818 wrote:Do you have a link to the new part? I can't seem to find it.
No link, the part number came from La Marzocco. I ended up ordering it directly from La Marzocco as they confirmed that it works on Linea Mini.
blondica73
#6: Post by blondica73 »
I received the new part yesterday and replaced the gicleur last night. The old gicleur was very tight in, but with the correct tools it comes out. After replacement, the flowrate dropped to about 290g/30 seconds. The shots look better, more forgiving.
