Gaggia Gicar control board question
I could certainly work it out by using trial/error and observation. I am guessing that one or two of the switches would control the preinfusion on the first and second buttons on the touchpads. Apart from that, what else could there be that would require that sort of control?
Does anyone have any suggestions?
Not much of an idea but have you tried Gicar's company website or e-mail them? I don't know off hand if they respond to consumer questions. Trial/error might let the smoke out.
Duke
Duke
P2= On Tea function with pump
P2= Off Tea function alone
P3= On Aux function with pump
P3= Off Aux function alone
P4= On Fill function with pump
P4= Off Fill function alone
P1= On increased probe sensitivity (I believe).
And CN6 is the serial port +, -, RXD data in, and TRX data out. Txd and Rxd must be jumpered for the board to function.
jpboyt
jpboyt
Thanks heaps for that info.
I put the new control board in the machine and everything works as it should. The old board needs to be looked at and I need to determine if it is worthwhile to fix it. At least I got the Gaggia 3 grp D90 working again. Another old beast saved from the scrapheap!
Once again thanks.
Here's a pic of the old beast.
Once again thanks.
Looks good.
I am rebuilding a 3 gp D90 at the moment. I thought i was cruising till i discovered that the power lead has been removed from the machine. I have got another one but the switch is not wired as the diagram on the inside of the panel says it should be!!
Do you know how the switch should be wired? Do you have access to a wiring diagram?
Any help would be much appreciated.
regards
Paul
regards
Paul
