Flojet and Roller Pump question
I have a practical question the use of a Flojet Pump.
http://store.waterpumpsupply.com/fldidepu14gp.html
The littlest 12V pump, 1 gallon per minute (link above) is rated for 30 psi. I assume that that is the maximum head it can pump against- but does anyone have experience with the backcheck valve on flojets? Is it fairly robust? I would like to know if the pump could handle a backpressure of say 10 bar without failing. I didn't see the answer in reading the specs - just that there is one.
Also, has anyone used roller pumps (peristaltic pumps) in an espresso environment? They might be quite easy to manually control.
Thanks
Joe
Thanks
Joe
PocoJoe
Safety Third- First Roast, then Grind
- HB
- Admin
That's a lot of pressure; I would add a check valve.pocojoe wrote:I would like to know if the pump could handle a backpressure of say 10 bar without failing.
