First Impressions of Decent Espresso DE1+PRO - Page 15
The soggy puck can be attributed to a number of factors. Headspace is one of the factors. Some other factors causing it is because of the unlimited parameters we can play with on the DE.
Slow preinfusion, bloom style, slow ramp up to pressure, slow ramp down, flow profiling etc etc during the shot will usually require a much finer grind setting, which increases the water holding capacity of the puck, which in turn causes the soggy puck syndrome. Infact a soggy puck usually indicates a a better extraction, as it means a well saturated puck.
The DE can produce tradition easy knock out pucks if you stick to the "tradition" extraction style. 30 secs, 9 bar, no preinfusion.
As long as the end result taste good, I don't think wet pick matter much. How does it taste?
I have v1.1-my pucks are a bit watery with some profiles. When the shot is amazing, watery puck is not a bother!sfhoo wrote:Did you get the v1.1? Does the shorter grouphead space help with the watery puck?
Excellent shot. My husband (my taste tester) was able get the fruit notes he was looking for from our ethiopian Wolichi Wachu home roasted medium beans. I am playing around with the long preinfusion profile (slayer style) on the DE1Pro.sfhoo wrote:As long as the end result taste good, I don't think wet pick matter much. How does it taste?
Thank you for the replied!! I pre-ordered the UL certified DE long time ago, then upgraded to UL listed DE+. Decent offered me the DEpro last year but I was not in the rush so waited till now.
I get soggy puck and great taste with the IMS screen. Considering trying the spacer just because is a rabbit hole. Going from Conical to MAX also.
