ECM Technika IV drip - Page 3
keno
Postby keno » Jan 29, 2013, 9:41 pm
I've adjusted the OPV to a slow flow at 11 bar and then dialed the pump pressure down to around 9 bar. Problem appears to be solved. Thanks Eric, you're the man!
BTW, pump is the Fluid-O-Tech CA054Z.
Cary, yes it's a switchable model. Mine is running off the tank in my current location but I thought it can't hurt to get the switchable model since it was the same price in case I ever move somewhere were my wife would let me put a hole in the countertop. If there were a price difference I probably would have gone for the tank only model.
NewEnglandCliff
Postby NewEnglandCliff » Feb 02, 2013, 9:49 pm
Keno, looks like they've upped the price on your model by $200.
Can you tell me how long it takes for your machine to reach operating temperature?
Dolce Vita,
NEC
erics
Postby erics » Feb 02, 2013, 10:56 pm
I'm not Keno (obviously) but you can count on 45-60 minutes based on numerous tests I have measured on a wide variety of machines.
Skål,
Eric S.
http://users.rcn.com/erics/
NewEnglandCliff
Postby NewEnglandCliff » Feb 02, 2013, 11:01 pm
You interrupted me from reading about one of your thermometers at Chris Coffee. You ARE the man.
Thank you!
Dolce Vita,
NEC
erics
Postby erics » Feb 02, 2013, 11:03 pm
Well, a sincere thanks . . . but the forum is the man as we all learn from one another.
Skål,
Eric S.
braekk
Postby braekk » May 25, 2013, 1:11 am
Hi
I just got my Technika Profi IV (switchable) 5 days ago and noticed something similar. 15 minutes after switching the machine on, this is how it looks. (picture attached) Not a lot of water, but it's dripping. I think this started yesterday, or I might not have noticed before.
When pulling a shot the pressure is 9 bar.
Should I be doing what Eric described?
erics
Postby erics » May 25, 2013, 7:36 am
Probably not as that "looks" right and certainly your brew pressure is set correctly.
Skål,
Eric S.
braekk
Postby braekk » May 27, 2013, 9:47 am
Thanks for you answer Eric.
I now noticed the infusion cylinder is dripping after I turn the machine off. Is that normal?
1 drop / 6-7 seconds. And slowly decreases to zero.
erics
Postby erics » May 27, 2013, 12:34 pm
The ideal procedure prior to shutting the machine down would be to do a plain water flush for about 5 seconds and then do a plain water backflush . . . once or twice.
If by "infusion cylinder" you mean the bottom of the group, then yes, a few drips are normal. Leakage from the fitting you showed in your pic should only occur during normal warm-up if the pressure in the heat exchanger circuit reaches ~ 11 bar due to thermal expansion.
Skål,
Eric S.
braekk
Postby braekk » May 27, 2013, 12:46 pm
I understand.
It drips from both as shown in the picture on my previous post (during warmup and after turning off) and from the picture (not my machine) I've attached on this post. This after turning the machine off.
