ECM Synchronika drain pan upgrade - Espresso machine drain plumbing - Page 4
Installed the new drain pan today, works like a champ. Much more volume and it does seem to evacuate better.
Thanks OP!
Thanks OP!
Thank you so much for creating this design and releasing it. I was lazy and had mine commerically 3D printed and it fit perfectly. I have been very happy with my Synchronika but the OEM drain interface was clearly a lazy afterthought. Your design works great so far.
Hey, I liked your drip pan that you made! Could you make me one? I don't have a 3d printer. Otherwise I would be all over it! I am willing to pay you for the time and material to do so.
Thanks
Thanks
Sorry I missed that last message !
Where are you located ?
** UPDATE **
Hi to all,
Been more than 1 year already since the first design and I noticed that my pan had twisted with the heat. The bottom curved and the wall twisted.
So I came up with an updated design, I just installed it in my machine and will see the evolution. Basically the new version has :
For those interested, I updated the Thingiverse :
https://www.thingiverse.com/thing:4665171/files
For those who tried it, let me know what your impressions and improvement suggestions !
Hi to all,
- Thicker walls
- Thicker bottom (Printed with 20% cubic infill
- Higher pan "floor" and designed a little pit inside for better flow
Hi,
Thank you very much for your sharing and update!
For 3D printing, did you use TPU or PLA? On Thingiverse description, I am not sure which one you used.
I will plumb my Synchronika soon, and I will install your awesome custom drip trait!
Thanks.
Thanks.
Good morning,
I used black PLA for both parts with cubic infill.
My 2nd design is more thick and did not have any problems so far ! Drains a little better also with the recessed "pit"
Let me know if you have any comments
Thanks !
Thanks !
Howdy - new guy here chiming in to say I appreciate OP's drip tray design. I just printed one of my own, after a few modifications.
Principally, I needed to be able to print it on a Prusa Mini+, with its 180mm build plate. Thankfully this only required clipping a few corners that were unnecessary.
While I was doing that, I also recontoured the interior and added some ridges in an attempt to trap some grit from entering the tube. We'll see whether that works or not.
I also got a bit too clever and added two embedded refrigerator magnets to try and keep the drip tray from shuffling as much as it does, but alas I remembered that this is a non-magnetic alloy of stainless steel. Oops.
I printed mine using PETG, which might do better than PLA at resisting thermal warp over time. Will report back.
Here are a few photos. If OP doesn't mind, I'd be happy to post the source file, STL, and Gcode to Thingiverse/Printables as a remix of his entry.
Two more magnets beneath the frame and it's awesome.jerrodh wrote: I also got a bit too clever and added two embedded refrigerator magnets to try and keep the drip tray from shuffling as much as it does, but alas I remembered that this is a non-magnetic alloy of stainless steel. Oops.
