ECM Synchronika drain pan upgrade - Espresso machine drain plumbing - Page 3
yeah i printed the countertop piece and calipers show it's slightly larger than 2"
Would you consider making the counter top adapter with a 5/8 barb rather than the 1"? I got a dishwasher drain hookup to the same P trap as the sink but it will only take a 5/8 hose.
Hey jmbinette.
Thanks for your drip pan design and install ideas.
I had the pan made at my local library for free and plumbed the entire system myself. Works great.
I used a 3/4 ID tube with a T connector at the hole in my counter to help drain. I cut in a p-trap and drain pipe that I run the hose to.
My local plumber wanted to charge me $500.
Congrats ! Looks great !!
Sorry guys, I just saw the question about the hole
I drilled a 51mm hole (+/-2in)
Hi there, do you by chance sell these upgrade drip pans for the ECM Synchronika? Thanks
I do not but I shared the 3D model for free.
can you find a local place to print it for you ? 3dHubs?
Thanks. the idea is great but the quotes are over $150 ... thanks though!
I will look around for places to print this (thanks for sharing!). I have never had anything 3d printed, where would you start looking? In NYC tri-state if it helps.
Maybe have a look at Shapeways or 3D Hubs ?
Not sure about the prices but should not cost much !
Let me know..
Let me know..
Look for a local fablab or library. They usually have a 3D printer.
If you were in Europe I'd print one for you.
